Polygonal Converter.
 1-12  …  413-432  433-452  453-472  473-483
6674.453 In reply to 6674.452
Hi keyi, there is an option in the importOBJ script to not normalize the object like it does by default.
There's some information here on the setting:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.201
To use it, modify your keyboard shortcut to give the parameter "exact", by adding it to the end of the shortcut separated by a space, so your shortcut should read like this:
_ImportObj exact
Also make sure you're running the latest one which you can find on Max's file archive here:
http://moi.maxsm.net/media/files/
6674.454 In reply to 6674.453
Thanks you so much for this, Michael!! This is now extremely helpful! Thanks!
Actually super cool to have both options since sometimes i want to have object in the middle when importing in Moi3D but most of the time i really need to be
at original position. Nice.
Once again, thank you! ;)
6674.455
the panel disappears or shows message "unsuppotred polygon type"
EDITED: 3 Jul 2016 by GLMR
6674.456 In reply to 6674.455
Hi glmr, please post the 3DM model file that you are trying to smooth when you see the error.
My guess though is that you have some faces in your object with 5 or more boundary edges on them. The converter will not work on that type of geometry, I think it requires all faces to have either 3 or 4 sides (triangles or quads).
6674.457 In reply to 6674.456
this one. it is not an inported model, but just an extrusion from .ai file
Size: 137 KB, Downloaded: 301 times, Dimensions: 951x526px
6674.458 In reply to 6674.457
Hi glmr, well I can see right away that you've got a top face on your extrusion which has 24 holes in it, which right there is not suitable for subdivision smoothing.
In order to do sub-d smoothing, your object needs to be made up only of 3 or 4 sided faces with no inner holes in any of them at all. So instead of one single face on the top with trimmed holes in it, the top part of an object like that needs to be tiled and made up of a bunch of smaller 4 sided faces that sort of flow around the holes.
Also you'd typically have an angular cage-like object as the base object to be subdivided, with all edges just being line segments, not starting out with curvy outlines like you've got there.
Sub-d modeling is a really different approach from a drawing based one like you're showing there.
6674.459 In reply to 6674.457
Hello,
try to export the file to .obj-format to get triangles and quads. Then reimport the result with the obj-importer written by Max Smirnov. After that - run the script:-)
Have a nice day
Karsten
6674.460 In reply to 6674.422
Hi Max,
can you help in install your subdivid beta9.
I have copied all the files (new importobj also) in the commands folder, but nothing happened.
Thank you for your help and incredible work in the created of subdivide surfacece.
6674.461 In reply to 6674.460
Hi gara,
Did you install a shortcut key in MoI Options icon?
For example: Select Options / Shortcut keys,
and add a new entry of your choice, such as Alt+F in first column, then _Subdiv_beta9 in the next column.
or for example, Alt+/ _Subdiv_beta9
The prefix _ must match the prefix of the _Subdiv_beta9.htm and .js files. _ is not required, but its presence or absence must match.
Then close and open MoI again, load a solid polygon, such as Box, select it, and type in the shortcut key combo,
for example hold down the Alt key and type F.
(I now use Max's custom ui for Ext.scripts, instead of shortcut keys, and also use _ prefix for the non-basic MoI scripts)
Either method, or both methods may be used.
EDITED: 31 Oct 2016 by BEMFARMER
6674.462 In reply to 6674.461
Thanks Brian,
now it works!
I had miss the step to close and open again MOI
6674.463
I have imported a simple object like a cube, and the obj importer works, but as I apply the subdivision and change the value with the slider appear an error, and if I click done the object disappear.
6674.464 In reply to 6674.463
Hi gara, the sub-d plug-in requires the object's faces to be quads or triangles, meaning all faces should have 3 or 4 boundary edges on them.
If you have something like a 5-sided pentagonal face in your object for example, that object will not be usable by the plugin and you'll get an error and behavior like you describe.
My guess is that's what you're running into, if you're not sure then please post the 3DM model file of your object so I can take a look at your particular case.
You would need to edit the model to be made up of quad faces before you can subdivide it, you can do this by drawing in some lines and using Edit > Trim to cut things into quads, or you also might try exporting out from MoI as an .obj file using the "Output: Quads & Triangles" option (not n-gons) and then importing that back in again.
6674.465 In reply to 6674.464
I have use a simple cube for test the plugin, so it has four edge.
I have try also a cube created in moi, but the result is the same
6674.466 In reply to 6674.465
Hi gara, over here I'm not able to reproduce any problem using a cube drawn in MoI.
What error message are you seeing?
6674.467
I don't know if I attach the image in the right way, but the error is this
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=140a23dbbe6dcd26987b7844d598d45e&filename=Immagine.jpg
Message 6674.468 deleted 31 Oct 2016 by GARA01
6674.469 In reply to 6674.467
Hi gara, are you possibly running an older version of the script? Try getting the latest one named Subdiv_beta9.zip from here: http://moi.maxsm.net/media/files/ .
Also what version of MoI are you running it with?
6674.470 In reply to 6674.469
With this new version works perfectly.
There is a way to check the tangency and curvature?
6674.471 In reply to 6674.470
Hi gara, MoI does not really have any tangency or curvature analysis tools currently, it's not a focus area for MoI.
But if you turn on metallic lighting and set some specular highlights on under Options > View > "Lighting options", you can look at the reflective highlights to see any major breaks.
6674.472 In reply to 6674.471
Ok, thank you Michael!
Show messages:  1-12  …  393-412  413-432  433-452  453-472  473-483
