Polygonal Converter.
 1-7  …  408-427  428-447  448-467  468-483
6674.448 In reply to 6674.446
Hi Tommy,
unfortunately my script doesn't support creases at the moment.
But you can try to use the split script to make a crease
EDITED: 7 Mar 2022 by SMIRNOV
6674.449 In reply to 6674.448
Hey Max,
awesome, thanks a lot - the good old techniques from the past before there was edge-weighting ;-)
That works pretty well for what I do at the moment, although it creates a tiny rounding instead of a really sharp corner.
Would you consider implementing sharp creases (for instance from an edge selection) or is that out of the scope of what you want to do with the script?
I would really love that feature.
But for the moment I'm very happy :-)
Thanks and Cheers,
Tom
6674.450
Hey Max,
it turns out it's not optimal to work with the multi-line-edges since they tend to create subtle wobbling and smoothing in places where you don't want them.
I can't use an OBJ mesh where the parallel edge-lines coincide completely (for a maximum sharpened edge), I guess the obj importer or MoI merges those away? But even with very small distance values, the Subdiv Script fails (no error message, it just doesn't do anything).
The smallest I seem to be able to go is 0.05 mm which still creates too much smoothness for some of my edges.
So I still would very much love to have a way to set completely sharp corners :-)
Thanks a lot,
Tom
6674.451
Thank you Max. You have a very good tool created for a fine Program.
Greetings from Berlin
Siechfred
6674.452
I was searching the forum here but didn't saw someone mentioned something regarding ImportObj script.
It seems like, if you have your objects in your other 3D app not perfectly world centered but instead somewhere in the scene - the ImportObj seems to completely ignore
object position/scale when imported in Moi3D, it will just import it in the center of the Moi3D scene. When you export back from Moi3D to other 3D app the object will not anymore be in the original position but instead centered in the middle of the scene.
What i usually do is when i model something in Maya and i see something would be just easier/faster/better to make in Moi3D, i will block it out and export as Obj then using ImportObj script import in Moi3D. At this point the object will not be anymore in original position/scale/rotation so when i am done working in Moi3D and export back to Maya i have to position/scale/rotate the object back in the original place again.
Is there a way currently for Moi3D and other 3D app get along nicely when import/export your object and for object to remember position/scale/rotation instead of, when you import obj, Moi3D to auto center it?
6674.453 In reply to 6674.452
Hi keyi, there is an option in the importOBJ script to not normalize the object like it does by default.
There's some information here on the setting:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.201
To use it, modify your keyboard shortcut to give the parameter "exact", by adding it to the end of the shortcut separated by a space, so your shortcut should read like this:
_ImportObj exact
Also make sure you're running the latest one which you can find on Max's file archive here:
http://moi.maxsm.net/media/files/
6674.454 In reply to 6674.453
Thanks you so much for this, Michael!! This is now extremely helpful! Thanks!
Actually super cool to have both options since sometimes i want to have object in the middle when importing in Moi3D but most of the time i really need to be
at original position. Nice.
Once again, thank you! ;)
6674.455
the panel disappears or shows message "unsuppotred polygon type"
EDITED: 3 Jul 2016 by GLMR
6674.456 In reply to 6674.455
Hi glmr, please post the 3DM model file that you are trying to smooth when you see the error.
My guess though is that you have some faces in your object with 5 or more boundary edges on them. The converter will not work on that type of geometry, I think it requires all faces to have either 3 or 4 sides (triangles or quads).
6674.457 In reply to 6674.456
this one. it is not an inported model, but just an extrusion from .ai file
Size: 137 KB, Downloaded: 301 times, Dimensions: 951x526px
6674.458 In reply to 6674.457
Hi glmr, well I can see right away that you've got a top face on your extrusion which has 24 holes in it, which right there is not suitable for subdivision smoothing.
In order to do sub-d smoothing, your object needs to be made up only of 3 or 4 sided faces with no inner holes in any of them at all. So instead of one single face on the top with trimmed holes in it, the top part of an object like that needs to be tiled and made up of a bunch of smaller 4 sided faces that sort of flow around the holes.
Also you'd typically have an angular cage-like object as the base object to be subdivided, with all edges just being line segments, not starting out with curvy outlines like you've got there.
Sub-d modeling is a really different approach from a drawing based one like you're showing there.
6674.459 In reply to 6674.457
Hello,
try to export the file to .obj-format to get triangles and quads. Then reimport the result with the obj-importer written by Max Smirnov. After that - run the script:-)
Have a nice day
Karsten
6674.460 In reply to 6674.422
Hi Max,
can you help in install your subdivid beta9.
I have copied all the files (new importobj also) in the commands folder, but nothing happened.
Thank you for your help and incredible work in the created of subdivide surfacece.
6674.461 In reply to 6674.460
Hi gara,
Did you install a shortcut key in MoI Options icon?
For example: Select Options / Shortcut keys,
and add a new entry of your choice, such as Alt+F in first column, then _Subdiv_beta9 in the next column.
or for example, Alt+/ _Subdiv_beta9
The prefix _ must match the prefix of the _Subdiv_beta9.htm and .js files. _ is not required, but its presence or absence must match.
Then close and open MoI again, load a solid polygon, such as Box, select it, and type in the shortcut key combo,
for example hold down the Alt key and type F.
(I now use Max's custom ui for Ext.scripts, instead of shortcut keys, and also use _ prefix for the non-basic MoI scripts)
Either method, or both methods may be used.
EDITED: 31 Oct 2016 by BEMFARMER
6674.462 In reply to 6674.461
Thanks Brian,
now it works!
I had miss the step to close and open again MOI
6674.463
I have imported a simple object like a cube, and the obj importer works, but as I apply the subdivision and change the value with the slider appear an error, and if I click done the object disappear.
6674.464 In reply to 6674.463
Hi gara, the sub-d plug-in requires the object's faces to be quads or triangles, meaning all faces should have 3 or 4 boundary edges on them.
If you have something like a 5-sided pentagonal face in your object for example, that object will not be usable by the plugin and you'll get an error and behavior like you describe.
My guess is that's what you're running into, if you're not sure then please post the 3DM model file of your object so I can take a look at your particular case.
You would need to edit the model to be made up of quad faces before you can subdivide it, you can do this by drawing in some lines and using Edit > Trim to cut things into quads, or you also might try exporting out from MoI as an .obj file using the "Output: Quads & Triangles" option (not n-gons) and then importing that back in again.
6674.465 In reply to 6674.464
I have use a simple cube for test the plugin, so it has four edge.
I have try also a cube created in moi, but the result is the same
6674.466 In reply to 6674.465
Hi gara, over here I'm not able to reproduce any problem using a cube drawn in MoI.
What error message are you seeing?
6674.467
I don't know if I attach the image in the right way, but the error is this
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=140a23dbbe6dcd26987b7844d598d45e&filename=Immagine.jpg
Show messages:  1-7  …  388-407  408-427  428-447  448-467  468-483
