Polygonal Converter.
 1-14  …  315-334  335-354  355-374  375-394  395-414  …  475-483
6674.355 In reply to 6674.354
Thanks Max!
6674.356
Max's Sub-D scripts are a blast! Here is my spin on a woman's dozen roses ring. Maybe I'll have one made for my wife. Anniversary is coming up:
Thanks again Max!
Michael T.
Some very rough notes attempting to document Subdiv_beta6,
Subtitle: Why is my solid not sub-dividable?
Thinking based upon solids referenced here: http://moi3d.com/forum/index.php?webtag=MOI&msg=7571.1
and here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.349
6674.358 In reply to 6674.357
Cool tuto!
French version ;) http://moiscript.weebly.com/subdivision.html
We are waiting images :)
6674.359
ImportObj v.1.5
[fixed] Normalization function bug
EDITED: 7 Mar 2022 by SMIRNOV
6674.360
Good news, guys :)
It seems I've found a way to avoid MoI JavaScript API limitations which stops me.
Beta7 is coming. Or maybe v1.0 ;)
6674.361 In reply to 6674.360
What a teasing and suspense!
API = Application Programming Interface
6674.363 In reply to 6674.360
Right on Max!
6674.364
Donate available on
http://moi.maxsm.net/
EDITED: 3 Dec 2015 by PAQ
6674.365
Tease indeed! :-/ Can't wait!
6674.366
First tests. Yes! It works!
6674.367 In reply to 6674.366
All wishes of success!
EDITED: 24 Sep 2015 by PILOU
6674.368
Ta-daa!
beta7
6674.369 In reply to 6674.368
Flash Gordon! :)
Seems works like a charm!
(Trick for volumes with difficulties like here : export as OBJ with triangles
then _importObj (BY Max ;)
and voilĂ !
(That I love in this one is that I have nothing to translate! :) (for the moment)
6674.370 In reply to 6674.369
Ops. bug found.
Pilou, download script again.
6674.371 In reply to 6674.370
No problem! I had not time to find it! :D
So the French one! ;) http://moiscript.weebly.com/subdivision.html
6674.372
Finally, I implemented a new method for extraordinary faces. In fact, I don't like this method.. I would like to have ability to create surfaces with different control point weights using Javascript interface, but now it is not possible. Michael, could you make it in the next version of MoI? (it will not take too much time, because the engine perfectly supports them.)
But yesterday I found another way. :) I can generate a temporary STEP-file with surfaces descriptions,exactly as I need, and then import it back.
So, I don't need to split an extraordinary faces to parts anymore. :)
Other notes:
High quality switch has been removed. Now preview is always generated in the fast mode, and result - in quality mode.
Also I have removed "Show points" switch. Just double click on title to make points visible.
I still have rare problems with LoadMesh function. I'll check it later.
The script doesn't support opened surfaces and extraordinary triangles (excluding a polar triangles)
6674.373 In reply to 6674.372
My volume above has not extraordinary faces ? (i must subdivise in triangles)
Or your next version will resolve this ?
6674.374
I hope that open surfaces and extraordinary polys are a possibility someday... it would be neat to create organic shapes ending in clean and straight openings.
Great work Max! I'll play with this update soon.
Show messages:  1-14  …  295-314  315-334  335-354  355-374  375-394  395-414  415-434  …  475-483
