Polygonal Converter.
 1-5  …  286-305  306-325  326-345  346-365  366-385  …  466-483
6674.326 In reply to 6674.324
Dang! Throwing down the gauntlet, I see. Nice.
6674.327
Yeah... I really regret not saving an earlier iteration.
I was caught up in the moment.
(I can't wait to see any further progress from Max ;-)
6674.328
So here is a re-do and a file for all to play with: :-)
http://www.mediafire.com/file/su0fmfcad2sq5g0/steering_wheel_%28try02.3dm
The finger grip ridges on the wheel was not really compatible with the angles of the column section, so I made them separately and then spliced them together using Blend.
Also one for that drone thingy earlier:
http://www.mediafire.com/file/on183n2q65jsg1p/drone01.3dm
EDITED: 23 Jun 2017 by MAJIKMIKE
6674.329
Hi
6674.330
Yeah! That's some great form work!
6674.331 In reply to 6674.330
"Yeah! That's some great form work!"
Indeed. Thank you, Mike and Lawrence.
Interesting how those sharp peaks in the starting form yield such a nice organic mouse shape.
" ...Interesting how those sharp peaks in the starting form yield such a nice organic mouse shape."
Yep - you have to over-exaggerate to overcome the SubD smoothing if you want ridges or more defined edges.
Takes some back-and-forth editing to get the desired result. Although, it does go quickly.
It would be nice to have a short cut key that gave a "preview" of the smoothed result, only when the key is pressed. That way you wouldn't have to "undo" each time as you iterate tweaking the underlying structure.
Would also be nice to have a symmetry mode so you're only concerned with one-half the model when editing.
Cool one!
That is a sort of "retro box modeling"! :)
6674.334 In reply to 6674.332
It would be nice if you could edit the control points of the box objects while previewing the result.
But yeah, a way to preview/review without undo-ing would be great.
6674.335
Hi guys,
I've been away from MoI for about 3 months, doing a lot of… yes… subdivision modeling in Blender.
Then I return to the forum and look at that, in the mean time Max turned out to have created a great subdivision toolset for use in MoI, I am amazed this is all possible in the shape of scripts.
Now those models that are hard to do using only NURBS tools — such as branching organic forms like hands — can also be tackled in MoI.
Way to go, Max! Keep up the brilliant work.
— Metin
metinseven.com — pixel art • illustration • 3D (print) models • characters • icons • logos • infographics • visualization • animation
The polyhedral solid known as the "great dodecahedron," was constructed in Moi, starting with an icosahedron, also made in Moi.
Planar was applied to the Pentagons in the icosahedron, and numerous trims were done.
_subdiv_beta six may be applied to the solid.
(File deleted to free up space.)
EDITED: 19 Nov 2020 by BEMFARMER
6674.337 In reply to 6674.336
Hello Brian,
if we had a "frame" plug-in we could do pretty nice things then with those kind of solids…
Here i used yours made a frame solid out of it and then applied 2x Max's subdiv script.
Well, just a thought about a "frame" plug-in…
(image 2 is just a quick test rendering)
Best regards
6674.338 In reply to 6674.337
Very nice art.
6674.339 In reply to 6674.337
For framing the edges, (Struts,) George W. Hart has an algorithm here, 43.9MB, and uses Mathematica.
http://www.georgehart.com/rp/Algorithmfor%20Constructing3DStruts.pdf
Had a preliminary manual try of making struts in Moi.
The triangles near the vertex can be placed with cplane.
Flip Lineweb and Sweep are useful. Did not do convex hull with vertex point...
3d printing seems to be the goal. There may be other software methods.
A few more links:
http://archive.bridgesmathart.org/2013/bridges2013-445.pdf
https://www.simonsfoundation.org/multimedia/3-d-printing-of-mathematical-models
http://archive.bridgesmathart.org/2002/bridges2002-37.pdf
6674.340 In reply to 6674.339
Thanks Brian,
and yes, 3D printing would be the goal.
Best regards
6674.341
Hey dear Moi-users, where I did find the latest edgeSplit - Script? I looks since a hour for that script :/
On Max Smirnovs website, i did miss that script
http://moi.maxsm.net/media/files/
btw. any news? ;) about the very cool subdivision-script-developments?
6674.342 In reply to 6674.341
Hi Lordfox, I think the edge split script is the file named sSplit.v.0.9.2015.03.28.zip , it's the 5th one down on Max's collection page on your same link (http://moi.maxsm.net/media/files/)
6674.343 In reply to 6674.342
Ok, thank you, I have the script, but I was watching a video in youtube about "edgeSplit" preview from last march and I was looking the whole thread about :) and also on other pages ...
6674.344 In reply to 6674.343
Hi Lordfox, sorry I don't know anything about edge split - maybe Max never finished that one up.
it's is working like shown in the video! :)
A very cool plugin!
Show messages:  1-5  …  266-285  286-305  306-325  326-345  346-365  366-385  386-405  …  466-483
