Polygonal Converter.
 1-8  …  229-248  249-268  269-288  289-308  309-328  …  469-483
6674.269 In reply to 6674.265
Great work Max, thanks for sharing all of these new tools!
Volume with Max Smirnov scripts goes in Sketchup and realtime rendered with the free Visualizer 1.3 ;)
http://getvisualizer.com/
EDITED: 27 Mar 2015 by PILOU
6674.271 In reply to 6674.269
Amazing. This makes a great bit of software even better. I cannot believe that this has become a toolset available in MoiV3. I was secretly hoping we might have it in V4.
It opens some exciting opportunities for the students I teach.
6674.272
sSplit 0.8
[Added] edge splitting
EDITED: 7 Mar 2022 by SMIRNOV
6674.273 In reply to 6674.269
Hi Michael
Thank you!
I have one question.. Do you plan to update MoI in nearest future? I mean x86 version. I will be happy if I could get some new features (and js functions) :) If it possible, of course..
6674.274 In reply to 6674.273
The last split zip is downloading as corrupted on my end.....
6674.275 In reply to 6674.274
my fault. fixed.
(it was 7z-archive with .zip extension :)
6674.276 In reply to 6674.275
Excellent!
6674.278 In reply to 6674.273
Hi Max,
Sorry, no I don't expect to have any updates anytime very soon...
Currently I'm experimenting with 64-bit stuff for v4, and still just in the early stages of that.
Knife is implicite!
A simple Boolean Diff makes the tricks! :)
6674.280
Max, I repeated Frenchy's little model above; and it worked as shown. But extruding other faces does not work, and results in an error [2] or error [4].
Can you explain a little about these errors, and what things to avoid before invoking sub-D command? I have seen some very complex models work fine in other demos.
Thanks for your fantastic tools!!
Ron
6674.281 In reply to 6674.280
Hi Ron,
The extrude tool sometimes split edges to parts. Try to select all edges and run Merge command.
6674.282
Thank you Max. Great work.
OT: We need a dedicated page where users can upload the latest version of their scripts. Asap. We can't follow the threads everytime to be sure of getting the newest version.
6674.283
subdSplit 0.9
now it uses pointpicker instead of slider
I'm very satisfied with the results
This version is close to 1.0.. Need to fix a couple of rare bugs :)
wastzzz
I made a site several months ago, but I haven't free time to fill it with information. Maybe someone help me?
Anyway, you can download all latest versions of my scripts here: http://moi.maxsm.net/media/files
6674.284 In reply to 6674.283
really nice work Max !!!
6674.285
very nice!! amazing. Thanks for taking time to work on this new plugin.
Very very cool ! Bravo!
but you don't answer me about an automatic selection of all new faces "Splited" at the end of the sSplit function?
Thank you Max - these tools keep getting better.
Can you explain usage of the Repeat check box on the latest Split tool?
I get stuck with an dialog box that I can't close, saying to pick an edge or a face, even though I already have a selection.
6674.288 In reply to 6674.286
Frenchy Pilou
Forgot about this. Sorry :)
When you asked me I tried to do this, but I couldn't done it successfully :(
When MoI joins separated parts it changes ID's of the faces. So I can't find which faces are new created.
At the moment I know only way to do it: create a new style. assign it to a new faces. join surfaces. restore selection. revert styles.
It will work, but I don't like this method.
I think we should ask Michael about this :)
Show messages:  1-8  …  209-228  229-248  249-268  269-288  289-308  309-328  329-348  …  469-483
