Polygonal Converter.
 1-2  …  223-242  243-262  263-282  283-302  303-322  …  483
6674.263 In reply to 6674.262
For kill the internal best is redraw a polygonal volume inside and make a boolean diff!
EDITED: 26 Mar 2015 by PILOU
Dedicated thread for Max's SubD Scripts?
With Max working on new scripts and folks experimenting and sharing results, maybe all posts related to his SubD work should go into a new thread.
6674.265
edgeSplit preview
A cup of tea! :)
EDITED: 27 Mar 2015 by PILOU
6674.267
Frenchy Pilou
>> what is the difference with View Points and use the Edit Frame ?
No differences in the v0.5. Check the new one.
My script determines center by averaging a source points. Edit frame uses boundary box center.
>> Does it possible to have Ngons like this ?
It's possible, but not now. My subd script doesn't support ngons.
blowlamp
>> Brilliant work like this shouldn't go unrewarded.
>> Can I suggest you get a Bitcoin wallet and start accepting donations through it?
Thank you. I'll think about it :)
EDITED: 7 Mar 2022 by SMIRNOV
6674.268 In reply to 6674.267
Cool last one!
6674.269 In reply to 6674.265
Great work Max, thanks for sharing all of these new tools!
Volume with Max Smirnov scripts goes in Sketchup and realtime rendered with the free Visualizer 1.3 ;)
http://getvisualizer.com/
6674.271 In reply to 6674.269
Amazing. This makes a great bit of software even better. I cannot believe that this has become a toolset available in MoiV3. I was secretly hoping we might have it in V4.
It opens some exciting opportunities for the students I teach.
6674.272
sSplit 0.8
[Added] edge splitting
6674.273 In reply to 6674.269
Hi Michael
Thank you!
I have one question.. Do you plan to update MoI in nearest future? I mean x86 version. I will be happy if I could get some new features (and js functions) :) If it possible, of course..
6674.274 In reply to 6674.273
The last split zip is downloading as corrupted on my end.....
6674.275 In reply to 6674.274
my fault. fixed.
(it was 7z-archive with .zip extension :)
6674.276 In reply to 6674.275
Excellent!
6674.278 In reply to 6674.273
Hi Max,
Sorry, no I don't expect to have any updates anytime very soon...
Currently I'm experimenting with 64-bit stuff for v4, and still just in the early stages of that.
Knife is implicite!
A simple Boolean Diff makes the tricks! :)
6674.280
Max, I repeated Frenchy's little model above; and it worked as shown. But extruding other faces does not work, and results in an error [2] or error [4].
Can you explain a little about these errors, and what things to avoid before invoking sub-D command? I have seen some very complex models work fine in other demos.
Thanks for your fantastic tools!!
Ron
6674.281 In reply to 6674.280
Hi Ron,
The extrude tool sometimes split edges to parts. Try to select all edges and run Merge command.
6674.282
Thank you Max. Great work.
OT: We need a dedicated page where users can upload the latest version of their scripts. Asap. We can't follow the threads everytime to be sure of getting the newest version.
Show messages:  1-2  …  203-222  223-242  243-262  263-282  283-302  303-322  323-342  …  483
