Polygonal Converter.
 1-19  …  220-239  240-259  260-279  280-299  300-319  …  480-483
6674.260
I figured i out :-)
first a pentagon
Then sSplit on both side, extrude the inner part to perform the bottom
sSplit on the side for the handle and copy the faces to direct the handle
sBridge it
And Subdiv
6674.261 In reply to 6674.259
Function Draw Curve Polygon
Extrude
Kill first polygon curve generator if not need
The trick : Select volume so a solid but sSplit need only faces!
So after select volumum (solid) use the Browser button for choise Faces ;)
Then use sSplit !
Et voilĂ
EDITED: 26 Mar 2015 by PILOU
6674.262
Excelent trick - merci
6674.263 In reply to 6674.262
For kill the internal best is redraw a polygonal volume inside and make a boolean diff!
Dedicated thread for Max's SubD Scripts?
With Max working on new scripts and folks experimenting and sharing results, maybe all posts related to his SubD work should go into a new thread.
6674.265
edgeSplit preview
A cup of tea! :)
EDITED: 27 Mar 2015 by PILOU
6674.267
Frenchy Pilou
>> what is the difference with View Points and use the Edit Frame ?
No differences in the v0.5. Check the new one.
My script determines center by averaging a source points. Edit frame uses boundary box center.
>> Does it possible to have Ngons like this ?
It's possible, but not now. My subd script doesn't support ngons.
blowlamp
>> Brilliant work like this shouldn't go unrewarded.
>> Can I suggest you get a Bitcoin wallet and start accepting donations through it?
Thank you. I'll think about it :)
EDITED: 7 Mar 2022 by SMIRNOV
6674.268 In reply to 6674.267
Cool last one!
6674.269 In reply to 6674.265
Great work Max, thanks for sharing all of these new tools!
Volume with Max Smirnov scripts goes in Sketchup and realtime rendered with the free Visualizer 1.3 ;)
http://getvisualizer.com/
6674.271 In reply to 6674.269
Amazing. This makes a great bit of software even better. I cannot believe that this has become a toolset available in MoiV3. I was secretly hoping we might have it in V4.
It opens some exciting opportunities for the students I teach.
6674.272
sSplit 0.8
[Added] edge splitting
6674.273 In reply to 6674.269
Hi Michael
Thank you!
I have one question.. Do you plan to update MoI in nearest future? I mean x86 version. I will be happy if I could get some new features (and js functions) :) If it possible, of course..
6674.274 In reply to 6674.273
The last split zip is downloading as corrupted on my end.....
6674.275 In reply to 6674.274
my fault. fixed.
(it was 7z-archive with .zip extension :)
6674.276 In reply to 6674.275
Excellent!
6674.278 In reply to 6674.273
Hi Max,
Sorry, no I don't expect to have any updates anytime very soon...
Currently I'm experimenting with 64-bit stuff for v4, and still just in the early stages of that.
Knife is implicite!
A simple Boolean Diff makes the tricks! :)
Show messages:  1-19  …  200-219  220-239  240-259  260-279  280-299  300-319  320-339  …  480-483
