Polygonal Converter.
 1-11  …  212-231  232-251  252-271  272-291  292-311  …  472-483
6674.252
Max.
Brilliant work like this shouldn't go unrewarded.
Can I suggest you get a Bitcoin wallet and start accepting donations through it?
Martin.
6674.253 In reply to 6674.243
Hey Max,
"""""""""I decided to write all subdTools scripts with basic functionality, and only after that I'll start to improve them."""""""""""
As someone who would love for you to start pumping out tools, I wanted to ask about the initial subD Command you've written.
Is there any more that can be done with this? Mostly regarding the lack of tangency and curvature between patches...... (It's kindof a killer for me personally)
Going along with your quote above, maybe you could do "all that you can" with this as the "main tool of the bag", before all the "timesaver" trick scripts.....
Thanks again :)
6674.254
sBridge - small bugfix
sSplit - n-gons support
sScale - new script
EDITED: 7 Mar 2022 by SMIRNOV
6674.255 In reply to 6674.253
Hi BurrMan
I have some difficulties with subd script. Unfortunatelly Moi javascript tools has very limited nurbs functionality. I can build curves of degree 2 or 3 only. I can't ajust control points weights. I can't build curves with double knots. etc..
So I need to find the way how to improve my script in this situation. But right now I'm tired of it. I need to switch to something else. So I decided to take a rest and write several simple scripts. After few weeks I'll continue my experiments with the main script.
6674.256 In reply to 6674.255
Understood.. Thanks again... :)
Excellent! What a productivity! Bravo!
PS sScale : what is the difference with View Points and use the Edit Frame ?
A trick for the sSplit : don't select the volume only, but select the volume then use the Browser for select faces! ;)
EDITED: 26 Mar 2015 by PILOU
@Max
sSPlit
Does it possible to have Ngons like this ?
And selected just after the sSplit ? :)
6674.259
Hi Pilou
How did you make the pentagon, and put the split inside?
I an trying to make a cup
6674.260
I figured i out :-)
first a pentagon
Then sSplit on both side, extrude the inner part to perform the bottom
sSplit on the side for the handle and copy the faces to direct the handle
sBridge it
And Subdiv
6674.261 In reply to 6674.259
Function Draw Curve Polygon
Extrude
Kill first polygon curve generator if not need
The trick : Select volume so a solid but sSplit need only faces!
So after select volumum (solid) use the Browser button for choise Faces ;)
Then use sSplit !
Et voilà
6674.262
Excelent trick - merci
6674.263 In reply to 6674.262
For kill the internal best is redraw a polygonal volume inside and make a boolean diff!
Dedicated thread for Max's SubD Scripts?
With Max working on new scripts and folks experimenting and sharing results, maybe all posts related to his SubD work should go into a new thread.
6674.265
edgeSplit preview
A cup of tea! :)
EDITED: 27 Mar 2015 by PILOU
6674.267
Frenchy Pilou
No differences in the v0.5. Check the new one.
My script determines center by averaging a source points. Edit frame uses boundary box center.
It's possible, but not now. My subd script doesn't support ngons.
blowlamp
Thank you. I'll think about it :)
6674.268 In reply to 6674.267
Cool last one!
6674.269 In reply to 6674.265
Great work Max, thanks for sharing all of these new tools!
Volume with Max Smirnov scripts goes in Sketchup and realtime rendered with the free Visualizer 1.3 ;)
http://getvisualizer.com/
6674.271 In reply to 6674.269
Amazing. This makes a great bit of software even better. I cannot believe that this has become a toolset available in MoiV3. I was secretly hoping we might have it in V4.
It opens some exciting opportunities for the students I teach.
Show messages:  1-11  …  192-211  212-231  232-251  252-271  272-291  292-311  312-331  …  472-483
