Polygonal Converter.
 1  2-21  22-41  42-61  62-81  …  482-483
6674.22 In reply to 6674.21
OSTexo,
500,000 was the max number of polys for T-Splines if a recall correctly from a few years ago.
Has this limit been increased?
Some of the work I have been doing just can't be decimated down that far. I'm trying to find something I can afford that will do a reasonable job of fitting nurbs to a high poly model, and does not cost $15,000 or more.
6674.23
Hello chrisd,
Don't try to convert your mesh to a T-spline. It depends on the scan, but I like to append faces and use the world retopology snap after laying out the general resurfacing plan. After some tweaking, adding and deleting edges and faces you are able to check your surface deviation within Rhino itself. In areas of detail you can go back and change density in specific areas, add creases, etc. In the end you'll be left with a much cleaner and lighter set of surfaces.
6674.24 In reply to 6674.23
The thing that I have found is LARGE SURFACE VARIATION = LARGE NURBS MODEL. There does not seem to be any getting around this one yet. Tooling producers will cry if you tell them you want to give them a triangulated model, but the nurbs representation can be just as large, or even LARGER than the triangulated version. I fail to see in many situations where the nurbs is actually going to better to machine from where there is a lot of surface variation.
6674.25
Hello,
I'm not sure I understand what you mean by large surface variation. I'd like to see a small example of what you're referring to.
Try Decimation Master of Zbrush before some exporting! ;)
6674.27 In reply to 6674.25
hows this?
Size: 340.7 KB, Downloaded: 249 times, Dimensions: 834x576px
6674.28 In reply to 6674.27
ZSurf and you will obtain a Nurbs surface!
http://www.kf12.com/blogs/techno/2007/08/zsurf/
6674.29 In reply to 6674.28
Hi Frenchy
Yes, ZSurf can do this for low levels of detail or debossing a logo, but really is not useful for more complex reliefs. It also does not import 16-bit greyscale files if I recall correctly.
6674.30
Hello chrisd,
Have you considered modeling the item to a specific level of detail, have the molds produced, then sending your molds to be engraved and textured appropriately?
6674.31 In reply to 6674.30
Osteo, I think I still do not understand what you mean.
If the mold was done in a 2 step process, would the last step of adding the fine detail need to be done from a nurbs model?
6674.32
Hello chrisd,
The engraving and texturing maps can be created from various bitmap and vector formats, they don't need to be NURBs. I believe you can also use scan data as well. I'd investigate having the items modeled to within a manageable tolerance, have the molds milled conventionally, then have the NURBs data, maps and/or scan data sent along with the molds so the detail can be mapped accurately to your molds. The molds are then engraved by subtracting a relatively small amount of material for the finish and detail you desire. I know you can accomplish this chemically, through EDM and laser ablation.
6674.33 In reply to 6674.24
Hi Chris,
"""""""""""" I fail to see in many situations where the nurbs is actually going to better to machine from where there is a lot of surface variation.""""""""""""
The NURBS will be preferred by your CAM system. With a NURBS model, you are allowing your toolpath generator to perform the path calcs and decisions with regard to the settings within the CAM system.
With a poly model, you will be forcing the toolpath calcs, tolerances, moves etc, in conjunction with the CAM settings, which is less desirable and can be problematic when you are doing precision work (especially molds)
Frenchy mentioned reducing the poly count, which I do a lot. The programs today are getting really good at this, but there are some considerations (mostly with molds)
Is DOES morph the intent (but so does the NURBS conversion), so if you are doing 2 part work, you will want to re-create the second/split half from the morphed result. The "decimation" can be done to allow for tolerances specked on the part.
I use 3dcoat for poly retopo's or "decimation".....
6674.34 In reply to 6674.33
While I understand the relation of surface finish and precision to the nurbs surface, I have explained to numerous vendors that I am not interested in high polish or extremely high precision surfaces.
The fact is most cam systems even now compute a toolpath based on a tesselated model derived from a nurbs model. Therefore, even though I may give a vendor a nurbs model, their machine is cutting it as G1 or straight line moves. So when they complain that they can't machine from from a triangulated model, that points out me they actually don't understand their own machining process very well.
Its quite funny actually when I asked to see sample G-code from one shop, to clarify this, they refused.
What I believe is happening is that most machine shops assume high precision work, and they won't stop and switch gears for projects that might be a little different from what they usually do.
6674.35 In reply to 6674.34
"""""""""The fact is most cam systems even now compute a toolpath based on a tesselated model derived from a nurbs model. Therefore, even though I may give a vendor a nurbs model, their machine is cutting it as G1 or straight line moves. So when they complain that they can't machine from from a triangulated model, that points out me they actually don't understand their own machining process very well.""""""""""
Well, yes to what you said, but:
Forcing the CAM program to generate it's path based off of the given little flat lines and patches and hundreds of thousands of edges (each requiring the calc to start and stop THERE as opposed to where IT DECIDES) is problematic for CAM programs and post processing into a proper toolpath. Some of your vendors may have just decided that the cost of problems that can arise because of that is not something they want to keep dealing with.
It's far better for the CAM program to be allowed to generate it's own little sliced up model based on the tolerances supplied within the system. Mixing those tolerances with the "forced dice" of a polygon model is hard at best.
Many CAM programs handle toolpath differently. Some will calc off of the "display mesh" created (way junk). These are the apps that will put a toolpath on a multi million poly model "really fast"... Some will just give you a set, hard coded tolerance which can burn past any of the really hard calcs. Most of the higher end stuff, will be looking at the surfaces supplied.....
CAM'ing a multi million poly model out when the specs are a little looser like you mention, is not super difficult, but it requires an understanding of the nature of the model. Not a lot of CAM shops are very versed in the underlying structure of the models they are working with. They are Machinists....
6674.36
Hello,
Trying to calculate an optimized toolpath through even 100000 points seems to be some insane traveling salesman problem, let alone millions of points. Perhaps the reason nobody wants to touch the job is because they realize that computationally it is not practical, and there are already well established alternative procedures that will provide an acceptable result.
6674.37 In reply to 6674.36
"Perhaps the reason nobody wants to touch the job is because they realize that computationally it is not practical"
That statement is simply not true.
If I had a mediocre CNC mill with a $2000 -$3000 CADCAM program like DeskProto or VisualMill (MasterCAM, SurfCAM, or Delcam not needed), I could cut this in steel myself. So the problem is not the file. And its not computation power.
I CNC milled files with more than a million triangles 15 years ago using DeskProto. Its ludicrous for a machine shop to say it cannot be done now.
6674.38 In reply to 6674.37
You have to read the entire sentence:
"""""""""Perhaps the reason nobody wants to touch the job is because they realize that computationally it is not practical, and there are already well established alternative procedures that will provide an acceptable result.""""""""""""
And then:
""""""""""Its ludicrous for a machine shop to say it cannot be done now.""""""""""
Remember to note the difference between "can not" and "will not"....
Could probably find a thousand hobbiests to cut stl's.... However, it will be different for guy's running mastercam on $100,000 machines, with employee's doing the machine work (and even the CAM work)....
6674.39
Hello chrisd,
Apparently you misunderstood my first statement which made my following statement unclear, I'm talking about calculating the optimal tool path from each point on each line of each triangle in relation to its neighbors. I'm not sure how you could say that my computationally impractical statement was not true. I didn't say it was impossible, but it is highly inefficient, and unnecessary given the other options that are available. Did the CNC mill each one of those million plus triangles poly by poly fifteen years ago? Of course not, tool paths were created from an input surface. But I guess that's the point, start with a lightweight surface set and add detail where needed through further secondary finishing processes that are appropriate for the desired output.
6674.40 In reply to 6674.39
A polygon surface meets my needs in terms of producing a finished product. I do not need aerospace finish or accuracy, which I have made abundantly clear in my dicussions about getting the work produced.
If I could machine a million plus poly surface 15 years ago, it can certainly be done now. Its as computationally intensive now as it was 15 years ago.
CNC machines can cut from polys or nurbs. They don't care. What matters is the CAM software that creates the toolpaths, and whether the CNC machine does spline interpolation from G1 moves on the fly.
If was concerned about finish and accuracy I AGREE that nurbs would be preferable for the reasons that have been stated, which I am previously aware of.
I talked to a shop that even had a license of VisualMill. The problem is not machines or software. Unfortunately its ignorance.
6674.41
Hello chrisd,
You milled an object based upon tool paths created from a million plus point mesh. That is another thing entirely than using the exact points of the mesh itself for the tool path and trying to optimize that route. I'm not sure it's ignorance on the machinists part, they probably know your requested process is not optimal, so rather than have an unhappy customer they'd rather pass on the work, it's a reasonable expectation.
Show messages:  1  2-21  22-41  42-61  62-81  82-101  …  482-483
