Polygonal Converter.
 1-17  …  178-197  198-217  218-237  238-257  258-277  …  478-483
6674.218 In reply to 6674.217
You are real experimentalist :)!
My Portfolio: www.samardac.com
A lot of my Tutorials!
Subscribe to my youtube channel: http://www.youtube.com/samardac
Russian community of MOI 3D: www.vk.com/moi3d
6674.219
Well, I've been having a lot of fun with it!
Michael T.
6674.220
ImportObj v1.2
New and almost fully rewritten version of the ImportObj script.
Now it always uses loft for triangles and quads and as a result produces a clean and editable grid.
Also improved normalization algorithm and overall speed.
Use "exact" parameter to disable normalization.
EDITED: 7 Mar 2022 by SMIRNOV
Cool!
Not yet French version but French section :)
http://moiscript.weebly.com/_importobj.html
6674.222 In reply to 6674.220
To: Max Smirnov (SMIRNOV)
Wonderful coding.
-JC
P.S. - Again, Thank you , from a Poly to NURBS Fan!
You're on the cutting edge here (more than some may comprehend) - FOLLOW THAT IDEA!
6674.223
Thanks Max, works great!!!
D/L file just needs to be renamed with ".zip" extension.
EDITED: 15 Mar 2015 by SBEECH
Size: 669.1 KB, Downloaded: 290 times, Dimensions: 1088x602px
6674.224
ImportObj v1.3 :)
Added status info.
Some internal changes.
6674.225
ImportObj 1.4
Made some fixes to avoid loft bug with very small values
6674.226
Thanks Max, amazing stuff!
6674.227
Max, Frenchy or anyone else.
Are the files at the front of this thread the latest and most current? If not, is there a standard place one can go to to get the most recent? Thanks for all the great work!!
6674.228 In reply to 6674.227
It appears that the most recent versions are in the more recent posts...
So start from the last post and work backwards...:-)
Yes! Stay awake! ;)
6674.230 In reply to 6674.192
I have a big problem, I used today SUBDIV Script first time, but now I can not import any OBJ, also after deleting the script I couldn't import any OBJ .. I didn't see that option since now ---
EDITED: 22 Mar 2015 by LORDFOX
Size: 469.5 KB, Downloaded: 150 times, Dimensions: 1920x1080px
6674.231 In reply to 6674.230
Hi Lordfox, re:
Sorry I don't understand this part - MoI does not itself import OBJ files, it's handled by Max's import script. So therefore if you delete the script like you say here then it's normal that you will not be able to import OBJs, because you just deleted the script that can do it.
Maybe you mean something else than that though?
6674.232 In reply to 6674.230
HI Lordfox, re: image attachment - yes that's normal that you wont' see OBJ listed there. MoI does not natively handle OBJ importing, if you want to do it, you need to use Max's plug-in command to do it. The plug-in is run as its own command, it will not show up in the file types list that you are showing there.
Currently MoI does not have any mechanism for plug-ins to extend the main file open dialog box. I do want to add that in the future but for now since there is no way for a plug-in to in to modify that standard list it's implemented as its own specific named command that you have to launch, rather than trying to use the regular File > Open.
6674.233
I'm sorry dear .. its okay, it works fine ... the subdiv script (beta 6) + the OBJ Importer. So happy :)
6674.234
Tiny but useful script - sBridge. The first one from my new set of tools for subdiv modelling.
This script makes connection between two polygonal faces.
6674.235 In reply to 6674.234
Subd modeling in MoI, how cool is that!
Very Cool !
Can we dream of something like Bridge 2 Faces of a same volume ?
Like this crazzy free TopMod ? http://code.google.com/p/topmod/
EDITED: 22 Mar 2015 by PILOU
6674.237
Hi Max,
Its quite usefull, thank you!
Show messages:  1-17  …  158-177  178-197  198-217  218-237  238-257  258-277  278-297  …  478-483
