Polygonal Converter.
 1-5  …  166-185  186-205  206-225  226-245  246-265  …  466-483
6674.206 In reply to 6674.204
PaQ
>>In attachment a simple scenario where continuity in lost.
I know about this. My script doesn't support non-polar triangles yet.
Right now I have another plans :)
1. Join splitted surfaces near extraordinary vertices.
2. Make support of opened surfaces (boundaries)
3. Overall surface optimization.
6674.207
Max,
Where would I find this command?
>>Use "_ImportObj exact" command to disable this function.
Michael T.
6674.208 In reply to 6674.206
Hi Max,
The plan sounds good :)
6674.209 In reply to 6674.207
Hi Michael
"exact" - it is not a script. It's a script parameter.
Type or bind command: _ImportObj exact
Last version of the ImportObj: http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.201
EDITED: 27 Feb 2015 by SMIRNOV
6674.210 In reply to 6674.209
Thanks Max!
Michael T.
Going off Michael's example in another thread, I wanted to make a shape by joining two solids (created with sweeps) using a loft. Works well.
Next I'll have to try making a real object.
EDITED: 9 Mar 2015 by EDDYF
Size: 16.9 KB, Downloaded: 119 times, Dimensions: 500x184px
6674.212 In reply to 6674.211
Hi Ed,
i also try making real object (with sweep, boolean, mirror , cut and join, and moving some point)
it's pleasant to try to do everything with MoI (without import)
6674.213 In reply to 6674.212
Excellent Lawrence.
I've never used a poly modeler as I work with mechanical shapes. But Max's script seems to fill a gap where you want the precision of Nurbs, but need some organic influence.
It's great this can be done entirely inside MoI. Probably not the preferred tool set to model a human head, but your eyeglass model is a perfect example of how I would want to use this script.
6674.214 In reply to 6674.213
I do not think that pseudo Poly technique with Loft as was shown with glasses can replace Polygons and Sub-D. What you can do inside MoI trying to replicate SubD with Max's plugin is very primitive shapes. Now MoI has SubD module but do not have any good polygonal tools.
My Portfolio: www.samardac.com
A lot of my Tutorials!
Subscribe to my youtube channel: http://www.youtube.com/samardac
Russian community of MOI 3D: www.vk.com/moi3d
6674.215 In reply to 6674.214
Hi Andrei,
i agree with you, MoI is not a polygonal modeler.
Perhaps some capabilities will come with version V6 or V7. I don't think that is a priority.
But I like to experiment this "pseudo technique" even if at begining i don't know where i go. Here it seems to be a snake skull :)
6674.216 In reply to 6674.215
LAWRENCE, how many time you spent for this skull :)?
6674.217 In reply to 6674.216
> how many time you spent for this skull ?
a moment of inspiration : one hour
6674.218 In reply to 6674.217
You are real experimentalist :)!
6674.219
Well, I've been having a lot of fun with it!
Michael T.
6674.220
ImportObj v1.2
New and almost fully rewritten version of the ImportObj script.
Now it always uses loft for triangles and quads and as a result produces a clean and editable grid.
Also improved normalization algorithm and overall speed.
Use "exact" parameter to disable normalization.
EDITED: 7 Mar 2022 by SMIRNOV
Cool!
Not yet French version but French section :)
http://moiscript.weebly.com/_importobj.html
6674.222 In reply to 6674.220
To: Max Smirnov (SMIRNOV)
Wonderful coding.
-JC
P.S. - Again, Thank you , from a Poly to NURBS Fan!
You're on the cutting edge here (more than some may comprehend) - FOLLOW THAT IDEA!
6674.223
Thanks Max, works great!!!
D/L file just needs to be renamed with ".zip" extension.
EDITED: 15 Mar 2015 by SBEECH
Size: 669.1 KB, Downloaded: 290 times, Dimensions: 1088x602px
6674.224
ImportObj v1.3 :)
Added status info.
Some internal changes.
6674.225
ImportObj 1.4
Made some fixes to avoid loft bug with very small values
Show messages:  1-5  …  146-165  166-185  186-205  206-225  226-245  246-265  266-285  …  466-483
