Polygonal Converter.
 1-15  …  156-175  176-195  196-215  216-235  236-255  …  476-483
6674.196
Hi everybody! :)
PaQ
>>I've some trouble to convert the oldman in high quality with the B6. The result (after a long computing time) is an half joined model.
Sorry, but I can't help in this case. My script on exit just starts Moi join function. It seems that moi has some problems with this hard job.
You can use this trick: Press Done. Press Cancel after that. You will get separated surfaces. Join surfaces manually, part by part. It works for me.
>>ChildHead.. Generate 524 errors, 474 recovered. While some faces are very distorted, it's a watertight SDS model.... The problem was not the topology, but the scale...
Yes. This model is too small. I used x100 scale factor in the ImportObj script - everything works great. I'll think how to solve this problem.
Frenchy Pilou
>>Problem with this solid ! (from Sketchup) Disapears!
In the last loadMesh I broke "unsupported face" alert. Will fix it today.
EDITED: 7 Mar 2022 by SMIRNOV
6674.197 In reply to 6674.195
Hi Will,
I'm used to launch the script with a key shortcut.
If you are using the command line, just type _Subdiv_beta6 (if you are using the last version of the script)
6674.198 In reply to 6674.195
Hi Will,
you need to install the latest version of Subdiv script
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.173
Unzip files to commands folder, press Tab, enter: _subdiv_beta6
P.S. ;)
6674.199
Okay thanks so much, guys - my SANITY has been restored!
This is an absolutely WONDERFUL plugin for MoI - yes, whenever that Paypal button is in place, make sure I see that link!
Max, you are The MAGNIFICENT!
-Will
6674.200 In reply to 6674.193
Imported the hippo head last night. Ran Blend on the open eyes and neck. Join. Subdivision6 worked well.
EDITED: 20 Feb 2015 by BEMFARMER
6674.201
ImportObj 1.0a. Test build.
Added function for scale and position normalization.
Use "_ImportObj exact" command to disable this function.
6674.202 In reply to 6674.201
Hi Max,
Thanks for the update, this normalization helps to successfully load many of my test models now ... wish there was a way to automatically scale the model back to his original size to avoid
model exchange issue between software.
Here are 2 models, the complete hypo and a rhino. (Hypo.obj and Rhino.obj)
Both models loads right with the new ImportObj, and I can join them as solids.
There are all quad and tris (no ngones), however Subdiv fails. Maybe the polycount is too high ?
Btw I just want to point an other surface smoothness issue. As I said previously poles are really top quality for my need, but the overall surface smoothness is still a little bit off.
SubdSmoothTest.rar
The issue is already visible in MoI viewport (especially if you lower the preview angle in the display option), but I have also export the result back in modo, with a really good mesh setting :
As I side note, I know that the mesh flow here can look very unusual. Actually the structure is very simple, is you manage to stitching surfaces with ordinary edges, you will end up with some sort of twisted cube.
If you manage to get better smoothing surface from this kind of topology, it means that 'we' could use tools like edges weight in our sds modeling package, we just had to freeze the geometry before export.
EDITED: 3 Dec 2015 by PAQ
6674.203 In reply to 6674.202
Hi PaQ,
thank you for your bugreports :) It really helps me.
>>wish there was a way to automatically scale the model back to his original size to avoid model exchange issue between software
Next version of the script will use constant scale factor (10x, 100x etc.) It will be easy to restore original size of the model.
There are four intersected faces in the rhino model. When moi joins them together it splits edges of this faces. Those quads has 5 or 6 edges. I'll try to solve this problem in the future versions.
>>Hypo..
I still have problems with loadMesh function. It's not stable with imported models which has bad structure.
Oh, it's a bug of the new loadMesh function :) Fixed. Please check the new version.
6674.204 In reply to 6674.203
You are welcome Max, I'm glad if that helps you.
Indeed a constant factor will help a lot to restore the initial size.
B6.1 works perfect now too, thanks a lot (happy it was 'just' a bug !)
In attachment a simple scenario where continuity in lost. I would never use this kind of topology for a real project,
but maybe it's still interesting for you !
6674.205 In reply to 6674.204
Thanks Max for this absolutely amazing tool!
Michael T.
6674.206 In reply to 6674.204
PaQ
I know about this. My script doesn't support non-polar triangles yet.
Right now I have another plans :)
1. Join splitted surfaces near extraordinary vertices.
2. Make support of opened surfaces (boundaries)
3. Overall surface optimization.
6674.207
Max,
Where would I find this command?
Michael T.
6674.208 In reply to 6674.206
Hi Max,
The plan sounds good :)
6674.209 In reply to 6674.207
Hi Michael
"exact" - it is not a script. It's a script parameter.
Type or bind command: _ImportObj exact
Last version of the ImportObj: http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.201
EDITED: 27 Feb 2015 by SMIRNOV
6674.210 In reply to 6674.209
Thanks Max!
Michael T.
Going off Michael's example in another thread, I wanted to make a shape by joining two solids (created with sweeps) using a loft. Works well.
Next I'll have to try making a real object.
EDITED: 9 Mar 2015 by EDDYF
Size: 16.9 KB, Downloaded: 119 times, Dimensions: 500x184px
6674.212 In reply to 6674.211
Hi Ed,
i also try making real object (with sweep, boolean, mirror , cut and join, and moving some point)
it's pleasant to try to do everything with MoI (without import)
6674.213 In reply to 6674.212
Excellent Lawrence.
I've never used a poly modeler as I work with mechanical shapes. But Max's script seems to fill a gap where you want the precision of Nurbs, but need some organic influence.
It's great this can be done entirely inside MoI. Probably not the preferred tool set to model a human head, but your eyeglass model is a perfect example of how I would want to use this script.
6674.214 In reply to 6674.213
I do not think that pseudo Poly technique with Loft as was shown with glasses can replace Polygons and Sub-D. What you can do inside MoI trying to replicate SubD with Max's plugin is very primitive shapes. Now MoI has SubD module but do not have any good polygonal tools.
My Portfolio: www.samardac.com
A lot of my Tutorials!
6674.215 In reply to 6674.214
Hi Andrei,
i agree with you, MoI is not a polygonal modeler.
Perhaps some capabilities will come with version V6 or V7. I don't think that is a priority.
But I like to experiment this "pseudo technique" even if at begining i don't know where i go. Here it seems to be a snake skull :)
Show messages:  1-15  …  136-155  156-175  176-195  196-215  216-235  236-255  256-275  …  476-483
