Polygonal Converter.
 1  …  142-161  162-181  182-201  202-221  222-241  …  482-483
6674.182 In reply to 6674.180
Hi PaQ,
the reason is perhaps the triangulation in ChildHead eyes and under the neck ?
6674.183 In reply to 6674.182
Hi Max,
So the oldman hi quality is working fine if I switch my unit into from meters to centimeters in MoI.
Hi Finema,
I don't think so, I have also tested the same model with 1 extra subdivision model (so I have only quads), but the loader still dont like it.
6674.184 In reply to 6674.183
PaQ,
I've modified ChildHead in C4D and close neck and eyes with quad and no triangles.
the subdivision in MoI is Ok now.
try it !
EDITED: 28 Jul 2018 by FINEMA
6674.185 In reply to 6674.184
Hi Finema,
Thanks for taking some time into this, it helps me to resolve the issue.
The problem was not the topology, but the scale.
Your model coming from c4d was 3300% bigger.
So I scale up my preview model by 2000%, and now it loads just fine, even with the ugly spiky topology on the neck and the eyes.
No problem to subdivide it either in MoI !
EDITED: 3 Dec 2015 by PAQ
6674.186 In reply to 6674.185
Great !!
Glad you have resolve this problem.
In my case, if i import object non solid (non closed) or with triangulate polygons, the panel Subdidision disapear when i try to subdivise.
6674.187 In reply to 6674.186
Curious !
The subdivision is OK when i test with your ChildHead-BIG.obj with triangle in neck and eyes....
Problem with this solid ! (from Sketchup) Disapears!
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/component_solid.skp
It's not directly the file, I import obj, Separate, Joint or Booelan Union, Move result beacause there are some alone lines (?)...
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/solid_from_skp.3dm
EDITED: 20 Feb 2015 by PILOU
6674.189 In reply to 6674.188
you have an ngon at the top and bottom. I think Max's script supports only tris and quads...
6674.190 In reply to 6674.189
Cool! Yes you right! Excellent!
The process
SKetchup -->obj By Tig for free version of Sketchup
Import OBJ --> Moi by Max
Export OBJ from Moi (Quad + Triangle) :) By Michael
Import OBJ by Max
Subdiv! By Max
Bravo Max! And Michael for the Quad + Tri) :)
6674.191 In reply to 6674.186
Hi Finema,
The panel disappear with non solid object here too, but no problems with triangles.
6674.192 In reply to 6674.191
Ok
Thanks PaQ
6674.193
Hello
I get an error if I import a object like known hypo or childhead. Can everyone tell me what is wrong?
Greetings from Bavarian
6674.194 In reply to 6674.193
I think there is nothing wrong.
If all the errors are recovered, you should see the model imported, and ready to be subdivided (after a join surface command)
6674.195 In reply to 6674.82
After hearing all the good buzz about this plugin, I'm trying to get it going but after following the instructions of unzipping into the Commands folder and calling the script, I keep getting "ReferenceError: Can't find variable: _subdiv_beta line 1..."
This is MoI v3.0 on Windows 8.1 Pro, I've already set MoI to run as administrator, which didn't help - what am I doing wrong?
I unzipped the htm and js files into the command folder and at first I created a command but now I'm just pressing tab and typing in:
script:_subdiv_beta
script:_Subdiv_Beta();
script:_Subdiv_Beta;
None of those variations work for me?
I've tried both the Subdiv_Beta2 and the 0.5.2014 versions - no joy.
I'm also having the same issue with ImportObj - sigh, it's frustrating to see this 3D stuff work for others whereas for me, it seems to never "click"...
Any help appreciated...
-Will
6674.196
Hi everybody! :)
PaQ
>>I've some trouble to convert the oldman in high quality with the B6. The result (after a long computing time) is an half joined model.
Sorry, but I can't help in this case. My script on exit just starts Moi join function. It seems that moi has some problems with this hard job.
You can use this trick: Press Done. Press Cancel after that. You will get separated surfaces. Join surfaces manually, part by part. It works for me.
>>ChildHead.. Generate 524 errors, 474 recovered. While some faces are very distorted, it's a watertight SDS model.... The problem was not the topology, but the scale...
Yes. This model is too small. I used x100 scale factor in the ImportObj script - everything works great. I'll think how to solve this problem.
Frenchy Pilou
In the last loadMesh I broke "unsupported face" alert. Will fix it today.
EDITED: 7 Mar 2022 by SMIRNOV
6674.197 In reply to 6674.195
Hi Will,
I'm used to launch the script with a key shortcut.
If you are using the command line, just type _Subdiv_beta6 (if you are using the last version of the script)
6674.198 In reply to 6674.195
Hi Will,
you need to install the latest version of Subdiv script
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.173
Unzip files to commands folder, press Tab, enter: _subdiv_beta6
P.S. ;)
6674.199
Okay thanks so much, guys - my SANITY has been restored!
This is an absolutely WONDERFUL plugin for MoI - yes, whenever that Paypal button is in place, make sure I see that link!
Max, you are The MAGNIFICENT!
-Will
6674.200 In reply to 6674.193
Imported the hippo head last night. Ran Blend on the open eyes and neck. Join. Subdivision6 worked well.
EDITED: 20 Feb 2015 by BEMFARMER
6674.201
ImportObj 1.0a. Test build.
Added function for scale and position normalization.
Use "_ImportObj exact" command to disable this function.
Show messages:  1  …  122-141  142-161  162-181  182-201  202-221  222-241  242-261  …  482-483
