Polygonal Converter.
 1-14  …  135-154  155-174  175-194  195-214  215-234  …  475-483
6674.175 In reply to 6674.171
Finema, I'm using MOI on a Mac.
Max, Wow great work!
Here is a mouse from a Cinema 4D example scene.
-Shane
rendering . animation . oddlyeven.com
Size: 310.5 KB, Downloaded: 236 times, Dimensions: 929x712px
Oldman works perfectly with v6! :)
6674.177
Thanks Max, for your work on this and other scripts!
I've been using it as a solid softener, works great!
Excellent!
PS Who is the author of Old Man ?
EDITED: 19 Feb 2015 by PILOU
6674.179 In reply to 6674.178
No idea Pilou, it's in the Modo content library.
Hi Max,
I've some trouble to convert the oldman in high quality with the B6.
The result (after a long computing time) is an half joined model.
I have join my .ini, maybe it's a scale/precision issue because of my settings ?
EDITED: 3 Dec 2015 by PAQ
6674.180
Here's a difficult model for you :)
Generate 524 errors, 474 recovered.
While some faces are very distorted, it's a watertight SDS model.
6674.181 In reply to 6674.173
Hi Max,
You are great !!
It's OK now on my mac !!
I've tested with old man and it's perfect !
Thanks for us !
6674.182 In reply to 6674.180
Hi PaQ,
the reason is perhaps the triangulation in ChildHead eyes and under the neck ?
6674.183 In reply to 6674.182
Hi Max,
So the oldman hi quality is working fine if I switch my unit into from meters to centimeters in MoI.
Hi Finema,
I don't think so, I have also tested the same model with 1 extra subdivision model (so I have only quads), but the loader still dont like it.
6674.184 In reply to 6674.183
PaQ,
I've modified ChildHead in C4D and close neck and eyes with quad and no triangles.
the subdivision in MoI is Ok now.
try it !
EDITED: 28 Jul 2018 by FINEMA
6674.185 In reply to 6674.184
Hi Finema,
Thanks for taking some time into this, it helps me to resolve the issue.
The problem was not the topology, but the scale.
Your model coming from c4d was 3300% bigger.
So I scale up my preview model by 2000%, and now it loads just fine, even with the ugly spiky topology on the neck and the eyes.
No problem to subdivide it either in MoI !
6674.186 In reply to 6674.185
Great !!
Glad you have resolve this problem.
In my case, if i import object non solid (non closed) or with triangulate polygons, the panel Subdidision disapear when i try to subdivise.
6674.187 In reply to 6674.186
Curious !
The subdivision is OK when i test with your ChildHead-BIG.obj with triangle in neck and eyes....
Problem with this solid ! (from Sketchup) Disapears!
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/component_solid.skp
It's not directly the file, I import obj, Separate, Joint or Booelan Union, Move result beacause there are some alone lines (?)...
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/solid_from_skp.3dm
EDITED: 20 Feb 2015 by PILOU
6674.189 In reply to 6674.188
you have an ngon at the top and bottom. I think Max's script supports only tris and quads...
6674.190 In reply to 6674.189
Cool! Yes you right! Excellent!
The process
SKetchup -->obj By Tig for free version of Sketchup
Import OBJ --> Moi by Max
Export OBJ from Moi (Quad + Triangle) :) By Michael
Import OBJ by Max
Subdiv! By Max
Bravo Max! And Michael for the Quad + Tri) :)
6674.191 In reply to 6674.186
Hi Finema,
The panel disappear with non solid object here too, but no problems with triangles.
6674.192 In reply to 6674.191
Ok
Thanks PaQ
6674.193
Hello
I get an error if I import a object like known hypo or childhead. Can everyone tell me what is wrong?
Greetings from Bavarian
6674.194 In reply to 6674.193
I think there is nothing wrong.
If all the errors are recovered, you should see the model imported, and ready to be subdivided (after a join surface command)
Show messages:  1-14  …  115-134  135-154  155-174  175-194  195-214  215-234  235-254  …  475-483
