Polygonal Converter.
 1-5  …  126-145  146-165  166-185  186-205  206-225  …  466-483
6674.166
So just to compare,
Max rules !
EDITED: 3 Dec 2015 by PAQ
6674.167
Hi Max,
Here's the oldman model already imported in MoI.
Looks like the geometry is ok (I had to join all surfaces in Moi, every faces were splitted after the import).
However the Beta5 don't seems to like it ... the object and the interface just vanish after few second.
6674.168 In reply to 6674.167
I've tested the Oldman on Mac OS X 10.10.2 and MoI V3.
1• open the Oldman.3dm
2• select the solid object
3• use Tab and type : _Subdiv_beta5
Result : object and subdivision panel disappears and have an empty vue.
6674.169 In reply to 6674.165
Hi PaQ,
>>I have the impression that poles area are looking even better than what I've seen with Npower sub-d Nurbs Oo ... the overall shape is much better now too !
Thank you. I hope it will be better :)
>>The last .obj loader works much better, but well ... it still fails with a lot of my testing models
Please send me testing models. It can help me improve my scripts.
It's ok. Automatic join function enabled only for simple models (<1000 polygons).
I know about this. This happens if there are gaps between the vertices of adjacent polygons.
Yesterday I rewrote loadMesh function. Now it works much better.
Wait for the beta6 today evening.
EDITED: 7 Mar 2022 by SMIRNOV
Seems now very cool! ;)
6674.171 In reply to 6674.170
Am i the only one on Mac ?
6674.172
Thanks for the update Max !
I'll test the new importer when it's released and I will post every models that don't work !
6674.173
As promised..
6674.174 In reply to 6674.168
Hi Finema,
try beta6 :)
6674.175 In reply to 6674.171
Finema, I'm using MOI on a Mac.
Max, Wow great work!
Here is a mouse from a Cinema 4D example scene.
-Shane
rendering . animation . oddlyeven.com
Size: 310.5 KB, Downloaded: 236 times, Dimensions: 929x712px
Oldman works perfectly with v6! :)
6674.177
Thanks Max, for your work on this and other scripts!
I've been using it as a solid softener, works great!
Excellent!
PS Who is the author of Old Man ?
EDITED: 19 Feb 2015 by PILOU
6674.179 In reply to 6674.178
No idea Pilou, it's in the Modo content library.
Hi Max,
I've some trouble to convert the oldman in high quality with the B6.
The result (after a long computing time) is an half joined model.
I have join my .ini, maybe it's a scale/precision issue because of my settings ?
6674.180
Here's a difficult model for you :)
Generate 524 errors, 474 recovered.
While some faces are very distorted, it's a watertight SDS model.
6674.181 In reply to 6674.173
Hi Max,
You are great !!
It's OK now on my mac !!
I've tested with old man and it's perfect !
Thanks for us !
6674.182 In reply to 6674.180
Hi PaQ,
the reason is perhaps the triangulation in ChildHead eyes and under the neck ?
6674.183 In reply to 6674.182
Hi Max,
So the oldman hi quality is working fine if I switch my unit into from meters to centimeters in MoI.
Hi Finema,
I don't think so, I have also tested the same model with 1 extra subdivision model (so I have only quads), but the loader still dont like it.
6674.184 In reply to 6674.183
PaQ,
I've modified ChildHead in C4D and close neck and eyes with quad and no triangles.
the subdivision in MoI is Ok now.
try it !
EDITED: 28 Jul 2018 by FINEMA
6674.185 In reply to 6674.184
Hi Finema,
Thanks for taking some time into this, it helps me to resolve the issue.
The problem was not the topology, but the scale.
Your model coming from c4d was 3300% bigger.
So I scale up my preview model by 2000%, and now it loads just fine, even with the ugly spiky topology on the neck and the eyes.
No problem to subdivide it either in MoI !
Show messages:  1-5  …  106-125  126-145  146-165  166-185  186-205  206-225  226-245  …  466-483
