Polygonal Converter.
 1-11  …  112-131  132-151  152-171  172-191  192-211  …  472-483
6674.152 In reply to 6674.151
I wrote a new version of importObj script. Now it works much better with twisted polygons.
I've tested this model with different version of subdiv script. Beta 2 and 3 works good. In beta 4 I wrote new LoadMesh function. Seems it have problem with this mesh. I'll check it today evening.
EDITED: 7 Mar 2022 by SMIRNOV
6674.153 In reply to 6674.152
always the same problem
panel subdivision split and disapear
6674.154 In reply to 6674.153
I need more information.
MoI version, script version, 3dm model (not obj. I need exactly that model, which you are trying to subdivide.)
6674.155 In reply to 6674.154
hypo.obj
MoI V3 (mac OS X)
_Subdiv_beta5, 4 ,2 or 1
6674.156 In reply to 6674.155
Hypo.obj is opened surface. Subdiv script works with solids only.
6674.157 In reply to 6674.156
ah ok !
6674.158 In reply to 6674.157
Anyway thank you :)
With your help I found a bug in LoadMesh function :)
Upd: fixed
EDITED: 14 Feb 2015 by SMIRNOV
6674.159
Well done Max!
Had a lot of fun with your importObj & Subdivision plugins.
Got this model from http://opengameart.org/content/low-poly-base-meshes-male-female
Dinos
<< I found a bug in LoadMesh function :)
<< Upd: fixed
So where are the last releases of load OBJ and Polygonal convertor ?
6674.161 In reply to 6674.160
6674.162
Just made some work and got this results first is original polygonal model, second is from T-Spline third from Max last beta.
T-Spline makes even less surfaces than on original but Max's script much more. Looks like a lot of geometry optimization must be done.
My Portfolio: www.samardac.com
A lot of my Tutorials!
6674.163 In reply to 6674.162
As I wrote before, it's just a first part of the script. The second phase is stiching surfaces with ordinary edges.
btw, can you check number of control point in t-spline model.
6674.164
Bonus script :) Subdiv Classic..
I wrote this script few months ago for testing purposes.
It produces subdivided polygonal surfaces using classical Catmull-Clark algorithm.
6674.165 In reply to 6674.164
Hi Max,
Thanks a lot for the last update, I'm really impressed by the result (and I can be very anal with that kind of stuff :)) ... I have the impression that poles area are looking even better than what I've seen
with Npower sub-d Nurbs Oo ... the overall shape is much better now too !
EDIT
The last .obj loader works much better, but well ... it still fails with a lot of my testing models (some sds cage model topology can be very distorted, with extreme non-planar quads).
Wish I could start to promote your converter with some famous models from the modo library (like the hypo, or the old man that npower also use for their own promotional material).
Maybe Michael can give you some advice in that area ?, he should know lots of stuff about file format ... because the converter itself is really amazing !
I hope the surface optimization will not change anything about the overall continuity quality !
EDITED: 18 Feb 2015 by PAQ
6674.166
So just to compare,
Max rules !
EDITED: 3 Dec 2015 by PAQ
6674.167
Hi Max,
Here's the oldman model already imported in MoI.
Looks like the geometry is ok (I had to join all surfaces in Moi, every faces were splitted after the import).
However the Beta5 don't seems to like it ... the object and the interface just vanish after few second.
6674.168 In reply to 6674.167
I've tested the Oldman on Mac OS X 10.10.2 and MoI V3.
1• open the Oldman.3dm
2• select the solid object
3• use Tab and type : _Subdiv_beta5
Result : object and subdivision panel disappears and have an empty vue.
6674.169 In reply to 6674.165
Hi PaQ,
>>I have the impression that poles area are looking even better than what I've seen with Npower sub-d Nurbs Oo ... the overall shape is much better now too !
Thank you. I hope it will be better :)
Please send me testing models. It can help me improve my scripts.
It's ok. Automatic join function enabled only for simple models (<1000 polygons).
I know about this. This happens if there are gaps between the vertices of adjacent polygons.
Yesterday I rewrote loadMesh function. Now it works much better.
Wait for the beta6 today evening.
Seems now very cool! ;)
6674.171 In reply to 6674.170
Am i the only one on Mac ?
Show messages:  1-11  …  92-111  112-131  132-151  152-171  172-191  192-211  212-231  …  472-483
