Polygonal Converter.
 1-5  …  106-125  126-145  146-165  166-185  186-205  …  466-483
Voluptuous!
6674.147 In reply to 6674.146
As in the beta4, The Subdivision panel displays a split second and disappears.
6674.148 In reply to 6674.147
have you tried to use beta 1 or 2?
6674.149 In reply to 6674.148
sorry, no i haven't...
Where can i find it ?
can i install both version on my mac ? V2 and V3 ?
thanks
6674.150 In reply to 6674.149
6674.151 In reply to 6674.150
i've tested with beta1 and beta2 and it's the same issue > the Subdivision panel disappear
in fact, the script run only with very simple object with low polygon (as cup in attachment)
but fail with more complex objects as hypo also in attachment
EDITED: 28 Jul 2018 by FINEMA
6674.152 In reply to 6674.151
I wrote a new version of importObj script. Now it works much better with twisted polygons.
I've tested this model with different version of subdiv script. Beta 2 and 3 works good. In beta 4 I wrote new LoadMesh function. Seems it have problem with this mesh. I'll check it today evening.
EDITED: 7 Mar 2022 by SMIRNOV
6674.153 In reply to 6674.152
always the same problem
panel subdivision split and disapear
6674.154 In reply to 6674.153
I need more information.
MoI version, script version, 3dm model (not obj. I need exactly that model, which you are trying to subdivide.)
6674.155 In reply to 6674.154
hypo.obj
MoI V3 (mac OS X)
_Subdiv_beta5, 4 ,2 or 1
6674.156 In reply to 6674.155
Hypo.obj is opened surface. Subdiv script works with solids only.
6674.157 In reply to 6674.156
ah ok !
6674.158 In reply to 6674.157
Anyway thank you :)
With your help I found a bug in LoadMesh function :)
Upd: fixed
EDITED: 14 Feb 2015 by SMIRNOV
6674.159
Well done Max!
Had a lot of fun with your importObj & Subdivision plugins.
Got this model from http://opengameart.org/content/low-poly-base-meshes-male-female
Dinos
<< I found a bug in LoadMesh function :)
<< Upd: fixed
So where are the last releases of load OBJ and Polygonal convertor ?
6674.161 In reply to 6674.160
6674.162
Just made some work and got this results first is original polygonal model, second is from T-Spline third from Max last beta.
T-Spline makes even less surfaces than on original but Max's script much more. Looks like a lot of geometry optimization must be done.
My Portfolio: www.samardac.com
A lot of my Tutorials!
6674.163 In reply to 6674.162
As I wrote before, it's just a first part of the script. The second phase is stiching surfaces with ordinary edges.
btw, can you check number of control point in t-spline model.
6674.164
Bonus script :) Subdiv Classic..
I wrote this script few months ago for testing purposes.
It produces subdivided polygonal surfaces using classical Catmull-Clark algorithm.
6674.165 In reply to 6674.164
Hi Max,
Thanks a lot for the last update, I'm really impressed by the result (and I can be very anal with that kind of stuff :)) ... I have the impression that poles area are looking even better than what I've seen
with Npower sub-d Nurbs Oo ... the overall shape is much better now too !
EDIT
The last .obj loader works much better, but well ... it still fails with a lot of my testing models (some sds cage model topology can be very distorted, with extreme non-planar quads).
Wish I could start to promote your converter with some famous models from the modo library (like the hypo, or the old man that npower also use for their own promotional material).
Maybe Michael can give you some advice in that area ?, he should know lots of stuff about file format ... because the converter itself is really amazing !
I hope the surface optimization will not change anything about the overall continuity quality !
EDITED: 18 Feb 2015 by PAQ
Show messages:  1-5  …  86-105  106-125  126-145  146-165  166-185  186-205  206-225  …  466-483
