small feature request for v3 final
All  1-6  7-16
6673.7 In reply to 6673.5
no, I'm not asking for inheritance, but simply a button to highlight a group name in the browser panel, so that newly created objects get that name automatically.
6673.8 In reply to 6673.6
Thanks Michael
> So when doing a union select the main one first.
That's what i thought
Martin spencer-Ford
6673.9 In reply to 6673.7
Hi wastzzz -
Ah ha, now i understand you. You want an active Object just as you have an active Style. I think this type of functionality will be coming with groups/assemblies/instances/hierarchy which we all know are in the pipeline for MoI. But as Michael says, it will be no mean undertaking for him and will take a lot of time and effort.
All the best
Martin Spencer-Ford
6673.10 In reply to 6673.7
It kind of feels like a somewhat odd button, currently for styles the swatch button serves another purpose of showing the color for the style. The button you're asking for would not serve any other purpose and could easily be confusing for people who would wonder what it was for... If you had any other idea for implementing it that would not have that kind of problem it would be easier to get it done sooner.
6673.11 In reply to 6673.10
Honestly I don't see many other options, having a checkmark as with styles sounds very simple to me. Maybe this feature could be activated with a .ini option, so that by default it's off. But look, this would change my life, because I spend a lot of time assigning manually the name to new objects, it's quite stressing even with the script. I often forget some objects.
6673.12 In reply to 6673.11
Hi Max,
Unfortunately it's not very practical for me to implement pieces with significant UI to them which are off by default, it becomes too likely later on down the road that there will be bugs in those areas when other things are changed, it becomes difficult for me to remember to test such things.
I'm not entirely against things that are activated with an .ini option but in general such things work better as a modification of existing behavior instead of being a major new feature themselves (like something that introduces its own UI is).
6673.13 In reply to 6673.12
You could implement that when you set a filter to a group name (by holding CTRL), new objects created automatically get the same name.
What about it? It sounds good to me for now. Please? :))
Regards,
Max.
6673.14 In reply to 6673.13
Hi Max,
Sounds kind of weird, I don't see how anybody would really expect for a selection filter to also change the name on newly drawn objects.
It's problematic to implement something that adds unexpected behavior like that.
In the V4 time frame when I'm working on more group functionality I'll see then if I can figure out any better method for doing what you want.
6673.15
What about no special UI, currently clicking on the name makes nothing. Maybe you can click the name and it gets highlighted and thats it. I know you plan to add special functions when you click on an object's name but in the meantime, this simple click and highlight can be an optional behavior that you can toggle on the .ini, having it turned off by default. It can be the left or the right click.
6673.16 In reply to 6673.15
Hi ed,
This kind of thing tends to be problematic - what ends up happening is someone gets used to the "temporary" behavior and then it causes a problem when the final changes are implemented that changes the behavior.
I tend to try to avoid that type of thing, I'd rather wait to implement something until I can do it in what I hope is more of its finished form.
Show messages: All  1-6  7-16
