Looking for advice on .stl export for object with flat curves
All  1-9  10-13
6672.10 In reply to 6672.8
> - I've also seen a 4mm wide patch of rough surface running
> up to the lower center of the flattest curve.
> - Other times there are fairly obvious oval rings around the center
It's hard for me to really follow the specifics of this - if you want more help getting better results in MoI it would be a lot clearer if you could post an image with these particular areas circled.
Just in general with a simple look (and in the screenshots I posted above) I was not able to see any of the problems that you are mentioning so that makes it a bit difficult to give you very good feedback about what you should do to improve it. My best guess though is that you want to use "Divide larger than" with a setting of "All" to force more even divisions throughout your mesh.
6672.11 In reply to 6672.10
I would say it will be a combination of settings.
So it appears he is having issues where "poles" are created for the stl mesh.
Poles are not necessarily bad and don't specifically make something "not smooth", but they can create effects when combined with the other settings that have to do with generating a path for the printer.
Although you have a high resolution printer, there will be settings that determine the print resolution. Various step/size settings for the print. Nozzle stuff etc.....
These combined with the sizes/counts of the polygons will affect the end result.
6672.12 In reply to 6672.10
Ricks problem is referring to the finished product from the 3d printer the mesh from MoI is fine it's when the mesh is put through the 3d printing software which slices the model to create paths for the printer according to what resolution is set for the specific printer so it's the resulting slices that are the problem.
Like Dinos I've had no such issue with my 3d printer exporting stl files from MoI.
6672.13 In reply to 6672.12
Hi Danny,
Yeah when your mesh is not dense enough it's possible for some aspects of the mesh structure to come through in the final print...
In order to avoid that you need to adjust some settings to produce a dense enough mesh to avoid seeing individual polygons.
The main settings to use for that are set an Angle fairly low, but then also use the "Divide larger than" setting to force a more uniform dicing of the mesh. From what I can tell from what he wrote, Rick has not used "Divide larger than" for the output he had difficulty with. It's hard to say for sure though without more specific information from him.
Show messages: All  1-9  10-13
