Duplicate line around two paths
All  1  2-11
6667.2 In reply to 6667.1
Trim the red lines with the blue circle ?
Martin Spencer-Ford
6667.3
I first put a point in the 3 O'clock position of the circle and ellipse and then used the Array curve tool to duplicate them around each shape, one at a time. That made it easy to snap a line between each pair of points.
Martin.
6667.4
Circular array and trim?
Marc
6667.5
You can also Sweep the first line around both paths using them as rails - then use Isocurves to also create the repeated lines.
You can also arrange more complex patterns by using Flow along the Sweep result.
6667.6
Thanks both for the suggestions but it's not exactly what I need. It's a litte difficult to explain 'cause English isn't my native language and I used a bad example I guess :). But here a new one. It's possible I have to deal with those shapes. So I those lines to be evenly distribute between the paths. So there's no overlapping and an even spacing. In the first one I used the outside path as 'rail' in the second one the 'inside'.
6667.7 In reply to 6667.5
Hi Mike
That's what I need :)!!! Thank you sooooooo much!!!!!!
6667.8 In reply to 6667.7
Can you show the result you were after as it's not really clear to me?
Martin.
6667.9 In reply to 6667.8
Hi Martin
I was looking for this:
Thanks guys :)!
Does LineWeb do what you want?
I think LineWeb script will work, but the start points may need to be aligned opposite each other, and possibly a Flip done.
EDITED: 2 May 2014 by BEMFARMER
6667.11 In reply to 6667.9
Hi, Wim3065.
It looks like you can use Mike's or my method depending on which is most convenient for you - glad you're sorted either way.
Martin.
Show messages: All  1  2-11
