Distort Curve script
 1-12  13-32  33-52  53-62
6659.13
Hi everybody! ;)
In my opinion this script can be very useful in some cases. I thought about it even before than Andrey asked for it.
EDITED: 7 Mar 2022 by SMIRNOV
6659.14
BurrMan, I made this Helix in previous post like in your video but insted of draw it by hands I used FX Graph by Max Smirnov that Pillow mentioned to produce randomly destorted curve.
Max, great thanx!!
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
Subscribe to my youtube channel: http://www.youtube.com/samardac
Russian community of MOI 3D: www.vk.com/moi3d
Very cool one for a more randomly world!
A little glitch! French version but...
Blocked Moi! Sorry I can't save the file but image will be sufficient :)
A sphere booelan Diff by a box ; Copy move only the Edges then distort but...
Select only the "edges"
EDITED: 1 May 2014 by PILOU
6659.16 In reply to 6659.14
""""""""""but insted of draw it by hands I used FX Graph by Max Smirnov """""""""""
I attempted that one first, but it is math formula oriented,, I would need to have the UI inputs be more like "more amplitude" and such, with a slider or human readable numbers.... lol
fx graph would be quicker than hand drawing. Maybe Brian or someone can combine fxgraph and flow for a 1 shot command that you wanted.....
6659.17 In reply to 6659.13
Very cool Max. I missed your post.
Now looking at your youtube, I see the "flythrough camera". Are you working on that or did I miss a post you made?
6659.18
BurrMan, all you need with that script is enter - RMD and it will produce randomely distorted curve, or RMD*10, RMD*20 etc...
Hay guys, Michael or anybody here who can made scripts could you pleas integrate in Distort Cuves v0.8, the rebuild command?
Now you have:
1. Rebuild curve
2. Run Distort Cuves
3. And if you do not like result go back to Rebuild to rebuil it again and than once again run Distort Cuves, and you have to repeat this actions till you will be satisfied.
It will be great to have rebuild integrated into Distort Cuves script to see imediatly result ant to be able to corect it on the fly.
Max have no time to modify this script so may be you will help to finish it?
6659.19 In reply to 6659.18
Hi Andrei, do you need all the different options and modes of Rebuild to be all built in or are you looking for one specific mode like "# of points" mode?
6659.20 In reply to 6659.19
Michael, one specific mode like "# of points" will be enough.
6659.21
v.0.9
[Added] Closed curves support
[Changed] Distort slider values. Now Distort(10) = +- 1 unit. If you use mm unit system, Distort(10) = +- 1mm. Distort (150) = +-15mm, etc.
[Fixed] Pilou's bug. (I can't reproduce it, but I added one more check. Now this bug should be fixed. Pilou, try this version.)
6659.22 In reply to 6659.17
Hi BurrMan
It was a tech demo :) I have an idea to write flycam script, but I haven't free time for it.
6659.23 In reply to 6659.21
Thanks Max!
6659.24 In reply to 6659.21
@Max
Works fine this time! :)
Except maybe some lines and curves of the Sphere ?
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/glitch.3dm
EDITED: 2 May 2014 by PILOU
6659.25 In reply to 6659.24
Frenchy,
"""""""""Except maybe some lines and curves of the Sphere ?"""""""""
The curves/lines need more points. Are those "2 point entities?"
6659.26 In reply to 6659.18
"""""BurrMan, all you need with that script is enter - RMD and it will produce randomely distorted curve, or RMD*10, RMD*20 etc..."""
Perfect. Thanks Andrei.
6659.27 In reply to 6659.18
Hi Andrei,
An updated version with rebuild built in is attached.
@Max - changes were: added a "Rebuild" checkbox and an input for number of points to use.
Added a RebuildCurve function and split init() into 2 functions init() and initpoints() so that when a rebuild option changes initpoints() can be called to extract points again.
Thanks for making this script Max!
EDIT: updated script to copy properties on to distorted version so style and object names will persist.
EDITED: 24 Jul 2014 by MICHAEL GIBSON
6659.28 In reply to 6659.27
Thanx Michael, works great, but one thing is have to be fixed for example if curve have 50 units long it works good but if curve for example have 2000 units long it does not work, nothing distorting... I have to enter value by hands.
EDITED: 3 May 2014 by ANDREI SAMARDAC
6659.29
And little tutorial, how I use this script to make curtain, in project I am workin on.
6659.30 In reply to 6659.28
Hi Andrei,
That doesn't have anything to do with the rebuild part, it's just how the script is currently set up, it uses a sort of base displacement of 0.2 units.
If you'd like something that's relative to the overall size of the curve rather than a more fixed size displacement, try changing the randomizePoints() function inside _DistortCurves.htm to this:
			function randomizePoints()
				for ( var i=0; i<curves.length; i++ )
					var size = scurves.item(i).getBoundingBox().diagonalLength / 20.0;
					for ( var p=0; p<curves[i].length; p++)
						curves[i][p].dx = size*(Math.random()-0.5)/5;
						curves[i][p].dy = size*(Math.random()-0.5)/5;
						curves[i][p].dz = size*(Math.random()-0.5)/5;
				lastdistort=-1;
This version puts in a scale factor that's related to the bounding box size of the object so the displacement on your 2000 unit long curve should work a bit more naturally this way.
6659.31 In reply to 6659.30
Michael, Thank you I'll try :)
6659.32
And sweet candy!!!
candy
Show messages:  1-12  13-32  33-52  53-62
