Blocks and Instances in Rhino5 files
All  1-2  3-5
6655.3
yes, instances is long time waited feature in MOI, but it looks like it is imposible... Very sad(
6655.4
It's not impossible, it's on the todo list. But I doubt if it will be friendly with Rhino's way of doing things (which is not that friendly, or at least wasn't when i last played with it).
Martin Spencer-Ford
6655.5 In reply to 6655.1
Hi Robert,
> When importing files from Rhino5, MoI seems to skip all blocks and instances.
Yes currently MoI only looks for "regular" objects and does not deal with block instances in a 3DM file.
> The only work around seems to save that first as step in Rhino. That works fine in MoI.
Another way is to use the Explode command in Rhino and then save as a different 3DM file, the Explode command in Rhino converts block instances into regular independent objects.
> Also, not sure if planed, Instances would useful in MoI.
Yup, it's definitely something I want to add in the future, I'll probably be digging into it in the v4 time frame.
Show messages: All  1-2  3-5
