Footwear
All  1-3  4-5
664.4 In reply to 664.3
Hi Juan,
> Will plug-ins be included for rendered, machinist (CAM), 3d print, print?
None of these will be included for version 1.0, but I would like to enable more in all of these areas in future versions.
For version 1.0 it is necessary to export your data to a different program to do any of these functions. But MoI does support several export formats that should work with other programs, for example use STL, IGES or 3dm to bring data over to a CAM program, or OBJ format to bring data into a rendering program.
664.5 In reply to 664.2
> 4. - to include conical extrude
Right now I was planning on including this for version 2.0. But here is a method that you can use to get the same result for the current version. Say you want to do a conical type extrude of this shape:
Like I posted in the new feature section ... a taper and a bend function that uses curves as rails would be better
that function could be used on curves as well ....
Show messages: All  1-3  4-5
