Network or anther strategy?
6637.1
Hello everyone, this is my first post here so getting a bit nervous...
As I'm getting used to MoI, I become more and more enthusiastic about it!
And so many tips and discussions here are really informative. Thank you very much indeed!
So far everything goes fine in MoI in case using 2D profile from AI and boolean operation.
But when it comes to Network, Sweep, Loft, I'm still quite struggling with making smooth surface by using them.
Having tried to network this but calculation has'nt been completed.
Maybe it seems bad strategy though...
I'd so much appreciate it if someone here could enlighten me.
Thanks!
Hisashi Kaneko
Size: 177.4 KB, Downloaded: 25 times, Dimensions: 822x793px
6637.2 In reply to 6637.1
Hi Hisashi, welcome to the forum!
Network won't work on that current curve layout because of this area here - here:
The problem is having 2 blue curves that touch each other on one side. Basically for Network to work right, you need to have 2 sets of curves like you have here with red and blue curves, but they need to form a regular grid layout similar to how lines of longitude and latitude on a sphere unwrap to a flat 2D grid on a flat map.
It's possible for the lines to touch each other such as at the north pole or south pole on a globe, but if the lines touch, _all_ of them belonging to the same direction must touch each other in that spot, you can't have only some pieces touch each other's ends (like you have here) instead of all of them collapsing down to a single pole area.
So anyway that's what is confusing Network for your particular situation here.
Also it will be difficult to get a smooth result with having a non-smooth back shape with sharp points as part of the structure here:
If you were to do a Network with a readjusted layout, those sharp zones along that back side would basically cause the network to be formed in strips with one strip for each sharp corner there rather than as a big smooth surface.
Do you have any images of the kind of end result you're looking for? If you can post something it may help to give better advice.
Right now looking at your curve outline though, I'd probably advise to initially create a more simple blocky object and then use filleting to round off the shape in these areas where you've got tight bends in it like here:
Generally a tight bend like that in between 2 longer straight sides is better done as an edge fillet rather than trying to directly model the tight bend in a single surface construction by sweeping or network like you're trying to do here... It's difficult to control surfaces when you use shapes that go through tight bends like that, it's better for an individual surface construction to be a sort of broader more uniformly curved shape and areas of tight "transition curvature" are done by fillets.
Something similar to these steps - here I've started with a boxy shape and put on fillets to make rounded spots, put in the biggest fillets first and then smaller ones:
So notice there how the end result of the filleting gives the kind of rounded corner footprint like you have in your curves.
I'm not 100% sure that this applies to your shape though, the angular sharp cornered part on the back part kind of confuses me a bit.
6637.3
Hi Hisashi and Michael G.
Another issue seems to be with the wireframe model itself. I tried to do some trimming and Network/sweep commands and found some non-intersecting curves:
Michael T.
6637.4 In reply to 6637.2
Thanks for QUICK reply!
WOW! that was so quick! Is it very early morning, isn't it? Apology...I live in different time zone(JAPAN).
Here is my reference image.
I do know that modeling a car needs much higher skill than I've had. So I just tried to get similar shape.
"Big surface and Filleting" method that I've seen here over again and tried to talk to myself while modeling in MoI.
But this time I completely screwed up(I've been thinking about how to model this even while I take a bath) .
Again thanks for attention to this and detailed explanation.
It gets me back to the basics and likely to adopt better approach.
So I'll keep on doing it.
Still much appreciate it if you guys could give me some advice.
Thanks!
Hisashi Kaneko
Size: 65.7 KB, Downloaded: 47 times, Dimensions: 438x344px
6637.5 In reply to 6637.3
Hi Michael T,
Thanks for your time and attension to this!
I did quick test to fix the part you pointed out, somehow I just succeeded in networking whole curves!
But I've noticed some tiny artifacts have been generated too...
As Michael G advised me, I think I'll have to reconsider an overall strategy for making this kind of model.
Anyway thank you very much indeed.
Hisashi Kaneko
