How you would made this ribbon?
All  1-5  6-11
6630.6
Thank you so much @all, also for the tip with the Mobius script, great plugin.
But by the way, I tried it made by hand, and one hour ago, I was happy, I thgought I need only some little tweaks, but I can't do it perfectly.
Thats my try out
6630.7 In reply to 6630.6
This jade one is pretty close.
EDITED: 14 Apr 2014 by BEMFARMER
Size: 42.2 KB, Downloaded: 70 times, Dimensions: 640x480px
6630.8 In reply to 6630.7
6630.9 In reply to 6630.8
Did you made this with the mobius script? looks nice ;)
I will try this script today. But By the way, it would be cool to have once a day better adjustment possibilities for the flow/deform. E.g. an start / endpoint e.g. ?
6630.10 In reply to 6630.9
Hi Lordfox,
Do you have an example where setting a start/endpoint would be useful? If you can post it that would help me to understand that better.
You should be able to control things like that currently by preparing the curve like using Trim to cut the target point to a smaller piece that then starts on your desired start point.
During the google hunt for how to do the triple twisted moebius, I came across three carving links, which would use similar techniques.
It is a subtractive process, which I want to try out in MoI. Four holes are drilled in the blank.
There is a for sale video for the jade carving artistry, as well as some free information on his website.
http://www.donnsaltjade.com/carve-a-moebius/
http://www.e-scoutcraft.com/wood_carving/mobius2.html
http://www.whiterivercrafts.com/mobius_ro_page.html
Show messages: All  1-5  6-11
