Hi Static,
> If it's posible it would be great to add a solid view option to MoI in the future tough.
Check out under Options / View, there are settings for "Display hidden-line curves" and "Display hidden-line edges". Sounds like you might want to turn those off.
> Why can't I make a hole in a surface just bye drawing an encloses shape
> (a new surface in the midle of the already existing surface), selecting that
> face of the closed shape and just delete it?
Well, the literal reason why is that it will take a bunch of work to make that happen, and there just isn't time to make version 1.0 do everything. When you draw new shapes in MoI, they are not attached to other existing surfaces, they are completely independent objects. In Sketchup this is different - Sketchup recognizes that you are drawing on top of an existing object and merges the new drawing into the existing surface. That's why you can do what you describe in Sketchup but not in MoI. In MoI you currently need to use a tool to cut the surface with the new curve, either Trim or a boolean would do it.
> Are there any shortcut keys in MoI?
Yup! There is a default set for common stuff like ctrl+s for save, ctrl+c / ctrl+v for copy/paste, etc.. You can edit them or create your own if you want, make sure you're running the latest beta and go to Options / Shortcut keys. See here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=35.1 or here:
http://kyticka.webzdarma.cz/3d/moi/ for more information and other useful scripts that you can put on a shortcut key.
> Is it posible to ad textures and materials like Glas and wood. Or wil MoI strickly be a Modeling tool?
For version 1.0 MoI is strictly a modeling tool.
> Are there any free easy to use render software that can be used for Moi or
> sketchup (this for future plans, first i'l stick to modeling wich i like most)
Try one of these:
Kerkythea:
http://www.kerkythea.net
Truespace 3.2:
http://www.caligari.com/products/truespace/ts3/default.asp
Bryce 5.5:
http://www.download.com/3120-20_4-0.html?tg=dl-20&qt=bryce%205.5
> I know that I first have to manage to get both ends of the handle glued to the
> surface for that. but i just can't do it!
The first step is it looks like your shape was kind of slanted in position to the path, so you've got kind of a sharp end. Let's chop off the sharp end so that it will meet up with the body of the cup better. To do this, switch to the front view and draw 2 lines, then select the handle, run Boolean / Difference, and select the 2 lines as cutting objects, then delete the small pieces:
Then I scaled that handle down slightly because it was currently running right into the joint between the center part of your cup body and the base part - that's going to make a difficult fillet there so it is best to make the handle only touch the body. Also, again from the front view move the handle so that it is intersecting the body. Then select the main body and the handle and use Boolean Union, this will combine the 2 pieces together:
Then select the 2 edges for where the handle meets the cup body, and then run Fillet. Here I used a radius of 1.0:
> I want to know that if the first complete version comes out, wil there
> still be a beta version whit out exiration date that's available?
No, sorry, there won't be a beta version without expiration date. If there was, there wouldn't be much reason to buy the final version!
There will be some kind of demo version, but it will be limited in some way like only being able to save a certain number of times or something like that.
