cplane copy-paste
All  1-3  4
6626.4 In reply to 6626.3
Hi Ditto,
> But the script I have found only gets me close to that, none of the other
> viewports are identical to the 3d. Any tip?
I'm not sure I understand properly, but do you mean you want to get a 2D result that has perspective in it like you see in the 3D viewport there?
If so you can't use the Project to the cplane to do that - projection on to a plane is a different kind of projection than a perspective projection.
But you can use the DXF output itself to generate that - instead of doing a project to cplane, save a DXF file and in the DXF output set the Projection view option to be "Projection view = 3D", then it will use the same projection you are seeing in the 3D view currently to generate the flattened output to the DXF file.
Show messages: All  1-3  4
