Joined Surface to solid failure
All  1-7  8-9
6614.8 In reply to 6614.1
Hi Martin, I was able to track down why there was a problem with joining that surface - it was due to Loft not using a tight enough fitting tolerance in some cases.
I've fixed it up so that in the next beta your original case here will work ok.
6614.9 In reply to 6614.8
Thanks Michael, It was the first time of running into the issue so i guess it would be a rare occurrence. Good job on tracking the little blighter down.
Martin Spencer-Ford
Show messages: All  1-7  8-9
