Joined Surface to solid failure
All  1-3  4-9
6614.4 In reply to 6614.1
Hi Martin, I'm not really sure exactly what's going on there, but I was able to get the attached solid version after rebuilding both the magenta piece and the smaller tube on one side of it all in one loft with the "straight sections" loft option.
Something seems to be getting confused for whether one of the previous edges was a closed curve or not, something like that.
Anyway I hope the attached solid version gets the immediate problem solved.
6614.5 In reply to 6614.4
Thanks Michael, I didn't use the straight sections option, so my guess is that it is that little extra help needed.
Many thanks Michael
Martin Spencer-Ford
6614.6 In reply to 6614.4
Thanks again for the help Michael .... Here's how it turned out :)
Martin Spencer-Ford
Size: 147.2 KB, Downloaded: 116 times, Dimensions: 1280x720px
6614.7 In reply to 6614.6
You're welcome Martin, wow that turned out very nice!
6614.8 In reply to 6614.1
Hi Martin, I was able to track down why there was a problem with joining that surface - it was due to Loft not using a tight enough fitting tolerance in some cases.
I've fixed it up so that in the next beta your original case here will work ok.
6614.9 In reply to 6614.8
Thanks Michael, It was the first time of running into the issue so i guess it would be a rare occurrence. Good job on tracking the little blighter down.
Martin Spencer-Ford
Show messages: All  1-3  4-9
