Keyshot and MOI
All  1-8  9-12
Martin -
I should have phrased my question better:
Is there a difference in the render quality using pure NURBs mode vs an obj output from MoI?
PS - There are a couple of "Ed's" on the KS forum. I'm the one that normally posts ring renders from models I've made in MoI:
https://www.keyshot.com/cascadia-design-studio-custom-titanium-ring-design-with-moi-and-keyshot/2011/
Ed
6609.10 In reply to 6609.9
Morning Ed. I hadn't tested macro/close-up renders until you just mentioned it, so here is link for the results ... Smooth as a babies bottom mate ;)
https://www.keyshot.com/forum/index.php/topic,8049.0.html to see the test results
Martin Spencer-Ford
** Edit **
Forgot to mention, KS5 new importer also supports the Style Colours and Names. It will also keep each surface as separate so you can assign a different material to each surface if needs be. It does not support the Object Names though, but that is of no real importance to me as a rendermonkey :P
EDITED: 7 Apr 2014 by TPWUK
Thanks Martin - Your example shows it works very well. Having one less translation in the workflow is a good thing, even though I've never had a issue with the MoI obj output.
It will be interesting to see how well KeyShot textures map to the NURBS. I've had to use box map on occasion rather than uv map in order to get textures to cover the model correctly.
Ed
6609.12 In reply to 6609.11
Give me an example of a texture and i'll give it a go. Most things modelled in MoI, i.e large sweeping surfaces tend to map fine, but once the fillets get added and other features that suddenly change the density of the mesh generated to keep things smooth is where NURBs really falls down from a rendering perspective. Simple materials and textures still do fine though, such as plastics, metals, paints etc. Simple bump maps like sand, moldtech and scratches all seem to map well. But things like woven cloth with pattern would most probably still be a nightmare.
Martin
Show messages: All  1-8  9-12
