Diff boolean
All  1-2  3-5
660.3 In reply to 660.2
Yes, I am trying to make holes at the top for a vent. I will upload the file monday since I am heading out the door and will be gone all week without computer access.
660.4 In reply to 660.2
here is the file :)
660.5 In reply to 660.4
Hi Dragon, the problem in this case is your cutting object has gotten a bit messy, it is made up of a lot of different pieces that are kind of overlapping over top of each other.
This is the problem piece:
If you select it an run Edit/Separate on it, you can then drag the faces that make it up, and you can see that they're kind of bigger pieces that overlap over top of each other:
That kind of overlapped surfaces inside one single object is not good, it will confuse the booleans.
To fix it, go in there and select the 5 bottom edges of the current shape:
And then do Edit/Copy. Now delete the whole object and then do Edit/Paste - this is the basic way to extract an edge from a solid as an independent curve. That should leave you with these curves:
Now run Construct / Extrude to punch those curves up into a new solid. This new solid will have a streamlined simple structure where each side is just one single surface - it will now work as a cutting object for your boolean.
Hopefully that should let some smoke out of your firepit! :)
Show messages: All  1-2  3-5
