InheritFromStyle option not working in last beta?
All  1-2  3-12
6592.3 In reply to 6592.2
It's the same file I sent you via email a couple of days ago. Anyways it's happening on new files as well!
6592.4 In reply to 6592.3
Hi Max,
What exactly is happening, could you describe a series of steps with particular commands you're using so I can try to repeat it over here?
6592.5 In reply to 6592.4
Well I draw a curve and put it on layer A. Then I set current layer to B, extrude the curve but the solid doesn't go on layer B!
6592.6 In reply to 6592.5
Hi Max, I'll investigate it some more when I return home.
6592.7 In reply to 6592.6
I installed latest beta on my other PC. For new projects, the option works fine, but for that one I sent you it's not working, I don't know why..
Thank you Michael, regards
Max.
6592.8
On my PC if I draw a red circle and then select the blue layer then extrude, I get a red cylinder.
I'm using Win7-64bit.
~Kevin~
6592.9 In reply to 6592.8
Draw a red circle. Select the circle and click on the blue style button. The circle then becomes blue ... then extrude.
cheers,
eric
6592.10 In reply to 6592.9
That's not what I need. I need to keep styles separated :p
6592.11 In reply to 6592.1
Hi Max, I've been able to track down the new bug in the last beta that was causing GeneratedObjectsInheritStyle=n to not work properly.
The reason why I could not reproduce it when you first reported it is that the bug is masked if the current style happens to be the very first style in the style list.
One workaround is after you do an extrude with GeneratedObjectsInheritStyle=n, if you immediately do an undo and redo, the result of the redo will pop into the proper style.
The bug will be fixed in the next v3 beta though which I'm hoping to not take too long to get out.
EDITED: 15 Apr 2014 by MICHAEL GIBSON
6592.12 In reply to 6592.11
Thank you Michael, I'm glad you discovered it's just a bug. I used that option a lot and I miss it so much :'(
Max.
Show messages: All  1-2  3-12
