How to create a catamaran hull nose using sweep?
All  1  2-4
6590.2
Yep, trying to finish off the tips of airfoil shaped objects has always been a problem in MoI.
The latest beta's of V3 have the ability to loft to point which should solve the problem for you.
Add a point to the nose of the hull and loft between your cross sections. You may need to add more cross sections in the nose area close to the point to get it to give you the desired shape.
If normal loft isn't giving you desired results, try the samardac method of loft, loose, exact.
https://www.youtube.com/results?search_query=moi+organic+loft+samardac&sm=3
~Kevin~
6590.3 In reply to 6590.1
""""""""""but I was not able to create the nose of the hull.""""""""""""""
Import this nose piece into your hull file and see if you like the looks of it...
6590.4
Hi Simba,
try this
1)I have added a scaling rail to give a smoother finish.
2) have used less of the cross sections.
3) trimmed the sweeped section to remove small distortion at nose.
4) mirrored and then blended the two halves.
Hope this helps.
Barry-H
EDITED: 10 Mar 2023 by BARRY-H
Show messages: All  1  2-4
