Hole repair
All  1-2  3-4
6571.3
First thing re: Cylinder thats not a Cylinder it is a Slug. A Cylinder is open there should not be closed ends. The is like a Piston which goes inside a Cylinder.
It should ask for Radius, Height, Base and Wall Thickness.
I am trying again I should be able to do this with simple extrudes.
Thanks for the reply.
edit......................................................
Well I know that is what's called a Cylinder but it's not the kinda Cylinder I am looking for.
Here is how I am drawing a closed end Cylinder (Can)
Drawing a Cylinder using MOI
Desired a one end closed Cylinder (Can):
20mm outside diameter
14mm inside diameter
3mm base
Start from Bottom view
Draw a Outside Circle name Outside (20mm)
Draw a Inside Circle named Inside (14mm)
Select both circles
Extrude 20mm Cap both ends
Select just the inside circle
Extrude 3mm
Boolean Union
Select all
Delete Inside
Delete Outside
Select all confirm Solid
EDITED: 23 Mar 2014 by RALPHXYZ
6571.4 In reply to 6571.3
Hi Ralph, another possibility is if you start with the base solid cylinder (draw solid > Cylinder), you can then use the Construct > Offset > Shell command to hollow it out and give it wall thickness.
To do that, after you draw your base cylinder, before doing the Shell select the top face (click once on the cylinder and then click a second time to "drill in" to select the face). Shell will make openings in the thickened result on the selected faces. So then run Construct > Offset > Shell and put in your thickness. The same thickness will be used throughout so you'll need to tune up the base still with that way with another extrude and boolean union.
Also instead of shell you can select the top face and run Construct > Offset> Inset , which has an option in it for making the inset depth to be set separately from the wall thickness. That's probably the overall least number of steps way.
Show messages: All  1-2  3-4
