Geometry problems
 1-13  14-33  34-53  54-59
656.54 In reply to 656.1
Hi Jacobo - I have found the bug that caused the problem in your original message of this thread (Cubos10.igs) - this is now fixed for the next beta.
656.55 In reply to 656.30
Hi Jacobo, I have looked at the second bug you sent, the one where it looks strange after the fillet.
This one is a bug in the geometry library that I'm using, it will be too difficult for me to fix right now. For this one I will have to wait until I get an updated geometry library which I don't expect to do until after the initial 1.0 version.
Actually, if you save to a .3dm file and then re-load that .3dm file, you will then be able to perform the fillet without that problem. This is because when you do the initial IGES import, there is a special flag on the cylinder object that makes the geometry library do some special processing which is supposed to be faster and more accurate for cylinders. But this special processing is the thing that has the bug in it. After you save to .3dm and reload, those pieces no longer have that special cylinder flag on them, so they are processed just as general NURBS surfaces, which in this particular case actually works better.
656.56 In reply to 656.55
Thanks so much for fixing those problems! I understand about the second bug, and
it's good to know there's an easy solution (save and reload the 3dm) to fix that until
you update the geometry library. I've tried it and it worked OK.
Sorry for not responding before... the las couple of days have been a bit crazy.
Thanks again!
Jacobo.
656.57 In reply to 656.11
Hi Jacobo & Josu - I've spent some time looking at this bug that you sent, that you showed here: http://moi3d.com/forum/index.php?webtag=MOI&msg=656.11
It appears to be a bug in Join. This model has some really tiny edges in it. Like there is a large surface, and some of the edges of the large surface are little lines around 0.005 units in length.
This is causing problems in the joining procedure, those little lines are getting flipped around and compressed and that produces some problems in the trimming boundaries of the joined object. Then these problems in the trimming boundaries (they are almost like small loops), are messing up the mesh export.
Unfortunately it is going to be difficult to fix this right now. It's kind of a delicate area, if I try to mess around with it, it is likely that I will mess up other things. So it might be a while before this particular one gets better.
One thing you can do is if you have any control over how these models are being exported to you, ask if you can receive the IGES data as IGES type 186 ("Manifold solid") entities instead of individual surfaces. That will maintain the joined-edge information in the IGES file, so when you read it into MoI it will come in as a joined solid already and that should work better.
656.58 In reply to 656.56
Hi Jacobo,
Don't worry, there isn't any rush. I've got plenty of other work to do in the meantime! :)
656.59 In reply to 656.57
Better later than never (my response, I mean :))
Thanks for the tip about the type of IGES. I was doing a couple of tests with another
problematic object, and it worked. So it seems to be a nice solution in those cases
you can have access to the original CAD model, or you just can ask for that when
somebody else is exporting that for you.
Thanks!
Show messages:  1-13  14-33  34-53  54-59
