Geometry problems
 1-18  19-38  39-58  59
656.39 In reply to 656.37
No problem Michael! Even with all quads, MOI still produces the best meshes out of any converter I've seen.
I just tested an import of a more complex object, I'm still getting polys flipped, despite joining surfaces, see attached.
656.40 In reply to 656.39
Hi Matt, was this when using an OBJ import into LightWave?
Their OBJ importer seems to be pretty buggy when trying to deal with complex N-Gons. You might try submitting that OBJ file to them so they can fix it up.
But that's why I'm doing the LWO format, because it doesn't seem to be as buggy as their OBJ importer.
In just a couple of days you'll be able to try and and see if it works better for getting N-Gons into LightWave.
656.41 In reply to 656.34
>You're welcome, yes I will include the LWO exporter in the next beta, it's going to probably delay the beta by a couple of days >though. Probably the bugs that you reported earlier (the filleted box and that other fillet one) will have to wait until the next one >after, but I figured that you would rather have LWO as a higher priority anyway.
Those are REALLY great news Michael. And for sure LWO is a higher priority for me, so I really appreciate
you're including that option in the next Moi beta. Seriously, thank you very much.
I agree with that; it's a shame that other 3D apps OBJ importers are not as good as they should. I can't understand how
today there's no full support for a so extended format. I think that formats like OBJ (for polygonal geometry), or MDD
(for vertex animation information), etc... should be full supported by any 3D application. But anyway... it's just a
thought... :O)
Again, I can't stop saying thank you for the LWO exporter, and for the great feedback you have with the users.
I hope all the issues we suggested over here help you in some way to make Moi a better application, instead of
driving you crazy :O)).
Jacobo.
656.42 In reply to 656.40
Yes it was an OBJ set to n-gons out of MOI. It also comes in that way if I set MOI to mesh with triangles only, so it's not just n-gons or quads that it freaks out on.
What's odd, is that it works fine for some objects and not others. I think it must get confused with objects that have 'insides' (if that makes sense!)
Look forward to testing the LWO exporter. I have a rendering job to do at the moment with CAD files coming from CATIA, would be great to have it for that!
:D
656.43 In reply to 656.42
Ok, can you guys test the attached .lwo file to see if it will go into Modo and/or LightWave ok? This one was produced by the new LWO export.
There are still various problems you will probably run into, there are some limitations in LWO / LightWave / Modo that cause problems with certain types of shapes, it's the same problem Gent was showing here: http://moi3d.com/forum/index.php?webtag=MOI&msg=656.16 - LWO does not have any way to specify the vertex normal smoothing information, instead it tries to average surrounding faces to create a shading normal, this will cause problems with some types of shapes.
If you run into these shading problems, you may want to turn "Weld vertices along edges" to OFF when exporting, that will create crisper style edges and avoid shading "leaks" between different surfaces.
When researching this, I saw this post: http://forums.luxology.com/discussion/topic.aspx?id=17281 which says that the next version of Modo will support vertex normals, so things might get better then.
656.44 In reply to 656.43
It's imported perfectly in LW and modo:
The smoothing seems to be OK in both of them... did you have to turn "Weld vertices along edges" OFF for
this example?
By the way... do you think you'll be able to include for this beta the option to use "Divide larger than" only for n-gons?
Great job!! Thanks for that!
656.45 In reply to 656.44
Great! Thanks for testing that! I've got the demo version of Modo over here but not LightWave right now.
I forgot to mention that this version also was done with an angle of 8, which didn't seem to work well in your OBJ test above.
> did you have to turn "Weld vertices along edges" OFF for this example?
No, not in this case, this one had welding on so there is only a single point shared between each polygon. If there are mostly fairly sharp corners between pieces it will tend to be ok.
When there are smooth pieces next to longer flat pieces, that's when you'll tend to get more shading problems. The way LightWave/Modo's shading currently works, a small somewhat angled polygon can have a pretty big effect on the shading of a longer flatter polygon next to it.
I'm pretty sure you'll run into some problems with that. Your main tools to try and reduce it will be either no welding, or try to divide things into somewhat more equally sized and angled pieces. Also if you have a longer polygon with a shading error kind of stretching out along it, you might also try manually dividing the n-gon into 2 polygons with one piece being short towards the end where the shading problem is coming from. That will tend to contain the shading problem more in the new smaller piece.
Also sometimes the real-time display will exaggerate the errors even more. When you see them try doing a full rendering, it may not be really quite as bad as it looks at first.
Only for planar surfaces you mean? Yup, I've finished this, the setting next to "Divide larger than" is now a drop-down instead of a checkbox, the choices are "Curved" (means apply the divide only to curved surfaces, not to planes), "Planes" (apply only to planes), or "All" (apply to everything).
Now I've just got to get back and finish up a couple of things that I put aside when I sidetracked to do the LWO stuff...
656.46 In reply to 656.45
Thanks Michael, I'm glad you decided to bump the priority of this for us Lightwavers - obviously you realize that this means us "old folk" ("old" meaning the tech used within LW) will be able to use MOI almost as much as C4D and other users.
I went to the C4D site to see what a full package costs - I nearly dropped my mouse like a hott potato when I saw $2200+...
(Not that I was really surprised or that it's not fair but I did sorta have a price in mind I was willing to uh, "swallow"...)
I just spent $1100 earlier this year upgrading my XSI to Ess - I think I will however download and eval C4D just to see what all the talk is about...
-Will
656.47 In reply to 656.45
Hi Michael Gibson!!
I am the friend of Jacobo, I am testing a lot of CAD Files in MOI and is VERY GOOD!!!
I work also with Lightwave and I am so glad if you can make the LWO Exporter. Actually in my tests I export the files in Quad and Tri...
cause with n-gons it make a lot of mistakes lightawave in the moment that import the obj file.
I found some new Visualization Bugs that if I have time I report to you or to Jacobo.
I sent to Jacobo some Plastic - Cad Files for your testing :)
Thank you very much for this work.
I am a user of Rhino too and this new program seems to be REAL GOOD FOR ME :)
As I have time I make more tests and report to you and Jacobo..
Best Regards
Josu
656.48 In reply to 656.47
Hi Michael!
About Visualization Bugs.
In some Pipes.... Moi make Strange Visualization. But when I go to export them, it looks good!!
You can see it in this two Images. Before Export and After.
This is another object from Solid Edge --- > Exported to IGES --- > And I use it for Export to OBJ --> Import Lightwave.
I am working a lot these days with MOI and I suppouse that I will found more thins ;) jeje. But this program is the best that I test for
import and Export. ( my old favorite was Rhino )
Best Regards!
Josu
656.49 In reply to 656.43
Michael, this is great, GREAT news!
Not that I want to push you, but when do you think this will released?
Oh and the issue with poly smoothing happens in LW when you create models too, so it's not an import thing (but you knew this!)
Once again, thanks for showing us LightWavers some coding love! It is very MUCH appreciated!
:D
656.50 In reply to 656.48
Hi Josu, thank you very much for sending the problem file! That will help me a lot when I try and debug the problem.
I will work on it just after this next beta is finished - I want to try and wrap up this current one so you guys can use the new LWO export. I think that should help enable you to get n-gons over more often instead of only quads and triangles.
MoI generally does a more careful job in the export (which is also much slower to calculate though), so sometimes you will find stuff like this where the display mesh has problems but the export mesh is ok. The display mesh sort of takes shortcuts in some areas to make it fast. I would still like to fix these problems, but I've put less priority on them than export mesh bugs.
Can you possibly send one of those problem tubes to me at moi@moi3d.com? Just one tube shape would be enough - I will keep your file private and not send it to anyone else. It always helps very much to have an example file so I can reproduce the problem over here.
656.51 In reply to 656.49
Hi Matt,
I'm hoping for tomorrow, if everything goes ok today....
656.52 In reply to 656.45
As somebody said (Matt I think), we still have that kind of problem when we create objects directly in LW/modo, so it's something
we can live with :)).
Yeah, that's what I meant :O)), and it's great you added that option! Thanks!
Well... I think you are going to make really happy (you already did) to a lot of people with this. I still don't remember where I've found
the first reference to Moi, but I know I was looking for some good way to export NURBS to meshes. Seriously... I think you did
something great here.
The way I see Moi, as a 3D rendering package user, is like a new great and very usable NURBS system almost 'into' my 3D application.
Thanks!
Jacobo.
656.53 In reply to 656.52
Fantastic!!! That is exactly what we need! Can't wait to test drive this new build!
Thanks Michael!
:D
656.54 In reply to 656.1
Hi Jacobo - I have found the bug that caused the problem in your original message of this thread (Cubos10.igs) - this is now fixed for the next beta.
656.55 In reply to 656.30
Hi Jacobo, I have looked at the second bug you sent, the one where it looks strange after the fillet.
This one is a bug in the geometry library that I'm using, it will be too difficult for me to fix right now. For this one I will have to wait until I get an updated geometry library which I don't expect to do until after the initial 1.0 version.
Actually, if you save to a .3dm file and then re-load that .3dm file, you will then be able to perform the fillet without that problem. This is because when you do the initial IGES import, there is a special flag on the cylinder object that makes the geometry library do some special processing which is supposed to be faster and more accurate for cylinders. But this special processing is the thing that has the bug in it. After you save to .3dm and reload, those pieces no longer have that special cylinder flag on them, so they are processed just as general NURBS surfaces, which in this particular case actually works better.
656.56 In reply to 656.55
Thanks so much for fixing those problems! I understand about the second bug, and
it's good to know there's an easy solution (save and reload the 3dm) to fix that until
you update the geometry library. I've tried it and it worked OK.
Sorry for not responding before... the las couple of days have been a bit crazy.
Thanks again!
Jacobo.
656.57 In reply to 656.11
Hi Jacobo & Josu - I've spent some time looking at this bug that you sent, that you showed here: http://moi3d.com/forum/index.php?webtag=MOI&msg=656.11
It appears to be a bug in Join. This model has some really tiny edges in it. Like there is a large surface, and some of the edges of the large surface are little lines around 0.005 units in length.
This is causing problems in the joining procedure, those little lines are getting flipped around and compressed and that produces some problems in the trimming boundaries of the joined object. Then these problems in the trimming boundaries (they are almost like small loops), are messing up the mesh export.
Unfortunately it is going to be difficult to fix this right now. It's kind of a delicate area, if I try to mess around with it, it is likely that I will mess up other things. So it might be a while before this particular one gets better.
One thing you can do is if you have any control over how these models are being exported to you, ask if you can receive the IGES data as IGES type 186 ("Manifold solid") entities instead of individual surfaces. That will maintain the joined-edge information in the IGES file, so when you read it into MoI it will come in as a joined solid already and that should work better.
656.58 In reply to 656.56
Hi Jacobo,
Don't worry, there isn't any rush. I've got plenty of other work to do in the meantime! :)
Show messages:  1-18  19-38  39-58  59
