File not found error
All  1-7  8-13
6555.8 In reply to 6555.6
And this random problem persists. For a while it wasn't happening, but today I can't seem to open anything after I just created it! Here is the error message. Rather "generic".
Size: 125.1 KB, Downloaded: 51 times, Dimensions: 701x443px
6555.9 In reply to 6555.8
Strange.... Are you trying to open the file by using the File > Open menu button inside of MoI or are you doing it by some other means like drag-and-drop ?
6555.10 In reply to 6555.9
If you're trying drag/drop, instead try launching MoI first and then use File > Open.
Maybe there is some problem with the drag/drop handling specifically on the older 10.6 operating system.
6555.11 In reply to 6555.8
Also do you have any punctuation or non-english language characters in the file name or directory?
It's possible that file paths with some particular punctuation characters like * in them (which are disallowed in Windows file names) may be causing a problem with drag/drop handling.
6555.12
I know this "rookie". She was dragging and dropping to open files. She didn't notice the "File Open" in the lower left hand corner (he-he). I think opening them from the file menu will solve the problem.
Michael Cramblet
Packaging Design
Phone: 616-574-6271
6555.13 In reply to 6555.12
Hi Michael C - drag and drop is supposed to work though, but in v2.5 if I remember right there was a problem when certain characters where in the file name or directory path, like * or / characters.
But this is supposed to be fixed in v3 - if it's not fixed and you can figure out which particular characters are causing the problem please let me know so I can try to reproduce the problem over here and get it fixed up.
The handling of drag/drop is quite a bit more complicated (with more layers between MoI and the operating system handling various things) than the File > Open menu so it's pretty likely that the file menu will not have the problem.
Show messages: All  1-7  8-13
