Resolution
All  1-2  3-5
6535.3 In reply to 6535.2
Thanks, I tried reproduce the model in origin it was working nicely filleted.
Actually I imported 3dm objects from Rhino and origin is not in the same position. I tried to replace by Cplane but got the same result. I just do not find the origin how can move to the origin ? no idea.
6535.4 In reply to 6535.3
All right, problem is solved. I found a command in Rhino to move to origin, now Moi and Rhino works together. cool.
6535.5 In reply to 6535.3
Hi andras,
In MoI you can use the Transform > Move command to do this. Start by selecting your object that you want to move, then run Transform > Move. For the base point pick a point on the object that you want to place at the origin.
Then for the target point, that's when you want to pick the origin. If the origin point is not easily visible on screen then instead of trying to pick it with the mouse just type in 0 and push Enter, that will specify 0,0,0 as the target point.
Show messages: All  1-2  3-5
