Door\windows script
All  1  2-6
6533.2 In reply to 6533.1
Hi Max,
Using Max Smirnov's UI add-on and once set up with objects it's pretty quick.
The video shows the intent, once set up properly with the right object orientation you'd be pretty right.
6533.3 In reply to 6533.2
Danny - Thanks for making your video demo.
For me, it shows how powerful having a built-in Object Library can be. Sure beats rummaging through your PCs folders.
Going a step further, it would be nice to have a user sharing database. Need a bolt? Someone probably has posted one to share (I know, there's a script for that). Need a toaster? Majik Mike may have one to share :)
Ed
6533.4 In reply to 6533.3
Hi Ed,
Check out http://grabcad.com - it's an online model repository that's generally similar to what you're describing here...
6533.6
Thanks, tried the custom UI, it makes my workflow actually easier :)
I'll just model a rectangle curve and place the profile already in the correct position for sweeping (in case I have to edit the size of the opening) and save it as a library object. Very comfortable!
EDITED: 25 Feb 2014 by WASTZZZ
Show messages: All  1  2-6
