MoI UI redesign
 1-18  19-38  39-50
6531.19 In reply to 6531.18
Hi Max,
> Anyway we can use a high resolution icons for high resolution screens.
That's what's happening already... The icons are quite a bit higher resolution (64x64 pixels) than what is typically displayed, the UI can already be increased in pixel size by quite a bit before there will be any actual stretching happening on the current icons.
Basically the current UI system already handles an increase in screen resolution very well, while at the same time handling lower resolution screens as well. It's just not something that needs to be messed with for this particular purpose because it's already doing that job.
6531.20
Hi Desudeus
I really like your icons.
Maybe its because i'm using a Mac as well or maybe its just a matter of aesthetic preference.
I'm not saying that the current icons are ugly! Actually, Moi has some of the best and most meaningful icons of any software i've ever used.
I will definitely try them once they are ready.
Dinos
6531.21
Thanks Dinos
Yes I'm on a Mac too so I like pretty icons :D
Here's some progress for the dark UI (icons are not all done yet)
Fun fact, you can use the new icons on both dark and light UI :)
Dark UI
https://dl.dropboxusercontent.com/u/44982094/MoIUI/NewUI1.jpg
https://dl.dropboxusercontent.com/u/44982094/MoIUI/NewUI2.jpg
Old UI with old icons
https://dl.dropboxusercontent.com/u/44982094/MoIUI/OldUI.jpg
EDITED: 25 Feb 2014 by SAMUEL ZELLER
6531.22 In reply to 6531.21
Hi DesuDeus, re: question about viewport title in your screenshot - sorry currently there isn't any way to adjust that particular color, it's drawn by the 3D engine not by any HTML so right now there isn't any way to change any CSS attributes to control that particular thing.
6531.23 In reply to 6531.2
I'm confused.... these look exactly like the current icons to me. What's the difference?
6531.24
Here's an advantage of the new icons, they work nice on both light and dark background
Comparaison with the original icons (left are untouched)
https://dl.dropboxusercontent.com/u/44982094/MoIUI/Icons_light.jpg (on white)
https://dl.dropboxusercontent.com/u/44982094/MoIUI/Icons_dark.jpg (on dark)
For example you see that the "Extend" icon doesn't work on dark background
The grid array icon has not the same size of the circular array one
The align icons have a weird aliasing
And so on... For now I'm just "fixing" little things
@Michael
Ok too bad, maybe in next version you could hide it with a script? I remember I asked if it was possible to turn them on/off for when you do high resolution screenshots :)
@Sun
That's because the current ones I'm making first are just a "relift", I will also do all the volume icons (sphere, cube etc..) and those will be really different
shapenoid.com
6531.25
shapenoid.com
6531.26
Slight update,
Fixed the checkboxes
Changed the "options" a bit
EDITED: 27 Feb 2014 by SAMUEL ZELLER
6531.27 In reply to 6531.26
Hi DesuDeus,
While I was skeptical about the need to redo MoI icons, I'm really fan of your dark UI version !
Thanks for the great job !
6531.28
Thank you PaQ, really appreciating your input (and modeling skills)
I use MoI nearly every day so I'll try to do my best to improve the UI
I hope I will be able to release the UI (not the new icons) in both dark/light versions for this weekend :)
For the new icons it will take a bit more time (there's like 105 of them)
shapenoid.com
6531.29
This looks really great - I like such dark GUIs a lot!
One question though: I and several other users I spoke to have a problem with the "tabs" in MoI.
To me, the brighter tab looks selected, not the darker one. No matter how many years I'm using it, I still get it wrong half the time. When there are three tabs next to each other it's a bit easier to get right, but with the Construct/Transform pair, I personally never have a clue which one is supposed to be active - I need to look at the available tools to understand it.
Recently I taught MoI to a woman who is really fluid using all kinds of software and it was interesting to see how even after a week of using it she still got it wrong most of the time.
It's one of the major design flaws for me in the MoI GUI actually - the tabs are not tabs at all, since they visually don't connect to the box they are attached to (they are closed at the bottom and don't have the same colour as the background of the box they are supposed to represent), nor are they changing to different front/back looks nor is the colour really obvious.
Your design does the same to my brain - the selected tab looks unselected to me.
So I wonder: Is it possible to have the selected tab open at the bottom and use the same background colour as the box it connects to while unselected tabs are darker (basically like CS6)?
Tabs are a funny thing, they either work directly on the brain stem or they don't work at all and need active thinking - which goes against every GUI-design-grain I have ;-)
Cheers,
Tom
6531.30
The dark UI looks very good to me, I would use that !
6531.31
Hi
i am using the dark UI with orange tap's from here http://moi3d.com/forum/index.php?webtag=MOI&msg=6025.1
It really motivate me, just when i open Moi (even though Moi motivate me by itselfe) and make me want to design something :-)
I wonder if it is possible to change the tap colurs to orange in your UI or i should stay with the UI i have and then just use your icons?
//Hep
6531.32
@Hep
Yes I could do a version with orange tabs (but it will not be the main version)
shapenoid.com
6531.33
Hi
No, that is no problem that it is not the main version. With a little guidens i have no problem with doing a little tweeking too. Lately i have used Moi a lot, and It would be very nice with that dark/orange look together with the updated icons.
6531.34
Little update
What do you prefer ?
The first one is more legible (more easy to see) while the second one is better looking (my point of view)
shapenoid.com
6531.35 In reply to 6531.34
I really love this dark scheme.. Great job...
Peace,
Rich-Art. ;-)
6531.36 In reply to 6531.34
The second one do look better. Perhaps a small reflection or light shaddow would make it easyer to see....
6531.37 In reply to 6531.31
Hi Hep,
I saw you are motivated with my UI zenox3d dark version.I'm glad you like it,and that makes you to design something with it.Maybe I made some distract elements,but it looks pretty modern and fresh.Maybe in the future I will try to create it also modern,but more pleased to the eyes for longer using.Moi3d and moi users deserved it.
Best Regards from zenox3d
6531.38 In reply to 6531.37
Hi zenox3d
Yes it is very cool looking. Somtimes when i have to do somthing else on my Computer I open Moi just incase - and the dark/orange look makes me start desingning.
Over the years (starting with version 1 beta) i have showed Moi3D to all my friends and recomented it every where i it was possible and they could see the bennefit of Moi but with the Dark/Orange theme they all say WOW - and start asking if we should do something :-)
//Hep
Show messages:  1-18  19-38  39-50
