Sweep V2 vs V3
All  1-7  8-14
6529.8 In reply to 6529.6
Also I've checked and it is indeed different in v2 versus v3 because of the changes made to intersection tolerances. Those changes were made about a year and a half ago.
The changes were a result of this example model posted here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5266.1 if you try sweeping that file, you'll see that v2 makes the weird result in that case, and v3 does it better.
Unfortunately the same change that made that file behave better made your particular case here behave worse...
6529.9 In reply to 6529.7
I did see it in couple of other occasions, after trying older files , builted in V2, related to this last project ( which I do in V3).
In other words, these odd shapes were done all in V2, except this last one.
This is where I tried the odd shapes that I did so far, in both V2 & V3
From what I have seen, V2 did a better, cleaner sweep (without the tweaking of control points), where V3 failed.
Rudy
6529.10 In reply to 6529.9
Hi Rudy,
> I did see it in couple of other occasions, <...>
If you happen to have those files handy can you please send them to me at moi@moi3d.com ? It could be good for me to check if they're the same kind of "almost tangent but not quite" type situation or something different from that.
6529.11 In reply to 6529.1
Hi Rudy, I've got this tuned up so your original file there will sweep ok in the next v3 beta.
If you do happen to have any other cases that you might have saved that also had problems, please send those over to me at moi@moi3d.com so I can make sure the tune up fixes those cases as well.
But anyway the tuneup should help with mitering these near tangent type cases.
6529.12 In reply to 6529.11
Thank you.
actually cannot find any other files with this different type of behavior in V2 and V3 beta. Thought I had one more, but it looks like not....if I find more, will send surely.
I usually make the "odd shape" half way, then mirror it, and delete the apex point (for sweep). It usually works in every case, except in this one.
Anyway Michael, pardon my ignorance, but I did not understand the changes you made at the shapes using control points....cannot find any visual difference (control point wise) from file I have submitted and the file you fixed. Can you explain, if you have more tolerance & time about this, the passage below
"...... Hi Rudy, here I've attached an updated version that has the pieces tuned up so they're smooth to one another. I did that by turning on control points and collapsing the endpoints and first inside points of each curve to be in a straight line. Now that they are smooth to each other rather than at a very slight sharp corner it should behave properly in both v2 and v3. "
Thank you.
Rudy
6529.13 In reply to 6529.12
Hi Rudy,
The difference is quite small so it's hard to see visually - it's changing some points that were at at about a one degree angle difference to each other to instead be in a perfectly straight line.
What I did first was to use Edit > Separate on the curve to break it into it's individual segments that make it up. That way you can hover your mouse over each one to see where each segment ends.
Then I turned on control points and zoomed in quite close to the end, there is a small cluster of control points at the end so you have to zoom in quite a ways to get just the last 2 points at the end of the curve:
Then I selected these points here - that's the end point and first inside point of each curve:
Then to true these up so the curves are smooth to one another, those should all be on one single straight line, to do that I grabbed the corner of the edit frame and moved it over until I got "flat" snap:
Hope that helps explain the tuneup!
Probably at some point in the future MoI will do something like this automatically to fix up curves that are close to being tangent to one another but just a couple of degrees off. I haven't done that quite yet because it's a little bit hard to judge how much of a change should be permitted.
6529.14 In reply to 6529.13
Thank you Michael,
really appreciate it.
Rudy
Show messages: All  1-7  8-14
