Scherk's second minimal surface script
 1-3  4-23  24-34
This script creates Scherk's First Minimal Surface. The surface looks like a saddle, and may even be useful.
The u and v angle parameters have intervals of (-PI/2, PI/2), inclusive.
Larger intervals do not work. This is probably due to division by zero?
A small absolute value for cValue makes the "saddle" flatter. When cValue is .00001, the grid is almost flat.
A negative cValue faces the horse in the direction of the x axis.
The maximum absolute value for cValue is coded to 1.0. cValue of zero is coded to 1.0.
Network works for cValue = .99.
A faster .htm version could be done.
EDITED: 2 Apr 2015 by BEMFARMER
6524.5 In reply to 6524.4
https://people.eecs.berkeley.edu/~sequin/SCULPTS/scherk.html
This tool is fantastic for easy transformations of any kinds on the basic minimal surface
- but I need to build some variations as based on Nurbs.
i hoped to reconstruct it in MOi by importimg an expoerted obf.file, bit no way.
So I hope to find somw helpful tips how to proceed in MOI
6524.6 In reply to 6524.5
Hi Tom, if the generator makes triangulated polygon data then that tends to be a difficult task to convert to NURBS.
One possibility would be to use retopology tools in 3D Coat or something like Topogun to get a quad polygon layout and then use Max's sub-d to NURBS script to convert that to NURBS.
The other possibility is to look at reverse engineering methods which are for converting triangle mesh scanned data into NURBS, often times these work similar to retopology methods where you trace out quad boundaries on the mesh and it fits NURBS surfaces to it. They tend to be rather expensive specialized tools though, see here for some links:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8460.2
Message 6524.7 deleted 13 Jul 2017 by BEMFARMER
6524.8 In reply to 6524.6
Thank you Michael. unfortunately I don´t own those tools.
Building up the curves is relatively easy, but generating perfectly
smooth surfaces is definitely not. see attachment. (Surface deleted already)
PS uploading attachment does not work
500 - Internal server error.
There is a problem with the resource you are looking for, and it cannot be displayed.
Attachment without the obj worked
EDITED: 14 Jul 2017 by SIRTOM
6524.9 In reply to 6524.8
@ bemfarmer
Is there a way to manipulate the parameters of your script so the saddle will match the blue curves of
the imported Scherk-Collins surface ?
EDITED: 15 Jul 2017 by SIRTOM
Size: 40.8 KB, Downloaded: 99 times, Dimensions: 700x760px
6524.10 In reply to 6524.5
Tom,
I recently 3D printed a model of this.
I got an .obj file from MathMod and then made it solid in MeshMixer.
I've just checked and can confirm that the MathMod .obj file can be imported into Moi using the importobj script.
Mike.
6524.11 In reply to 6524.9
Hi Tom,
Off the cuff, perhaps setting up a Frame, which "moves the x,y,z axi?"
What are the coordinates and orientation of your required position?
Or use Orient command?
EDITED: 15 Jul 2017 by BEMFARMER
6524.12 In reply to 6524.11
I ran the old sherk2 script again, and applied some different MoI commands.
Lineweb will form a curve between the endpoints of a bunch of curves originating from a single point, with point count = 2.
Rather than arc, Blend was used to connect the ends, then Join. The long lines were trimmed.
Network then works quickly.
Each blend arc and face was then deleted with a plane.
Move and rotate then extended the Sherk2 surface.
Size: 5.8 KB, Downloaded: 69 times, Dimensions: 160x120px
6524.13 In reply to 6524.10
>>I've just checked and can confirm that the MathMod .obj file can be imported into Moi using the importobj script<<
You are right and no problems there. Where I had problems was uploading the obj onto the MOI discussion forum
6524.14 In reply to 6524.12
Very good and thank you, Brian.
Hope I can follow your steps and will give it a try !
6524.15
Brian I realized I cabt follow the steps you layed out.
First, why have you used Scherk2 and not Scherk1 ?
6524.16 In reply to 6524.15
The Scherk tower is made with Scherk 2nd surface.
Your model resembles a Scherk tower, but reference is made to the Scherk-Collins surface (which is non-minimal)
so after rereading your post, I see that the "saddle surface ring" Scherk-Collins surface:
"can be formed by twisting and warping a singly-periodic Scherk’s minimal surface"
so I'm doing some more reading, both art and math... :-)
https://pdfs.semanticscholar.org/8ac1/d46735688959ec7f1f58a92dd268d0e1388c.pdf
The Scherk1
I did try out the mathmod and sculpture generator programs a bit.
I'm going to try stacking some Scherk1 saddles using c=0.99, u = 25, v = 25, 100 pts/curve, trimming the tops and bottoms,
copying above and below, rotate 90 degrees, blending, then network...
EDITED: 17 Jul 2017 by BEMFARMER
6524.17 In reply to 6524.16
Thank you for your input.
Ok thats clear now, I wasnt sure which of your scripts to use.
The original obj was created with this prog
Great functionality to interactively twist and bend all kind of Scherk towers
I transformed the file generated there into an obj, imported it into MOI
and built uo the curves manually expecting to find a way to create surfaces
out of them,
6524.18 In reply to 6524.17
There is source code for SculptGen. I've no idea if it can be modified to make nurbs, or which MoI commands could do
equivalent twisting and bending...
After work I'll try to blend together the Scherk1 script output.
The Scherk1 surface can be copied/moved, by PI units in the x direction and also PI units in the y direction, checkerboard fashion.
PI (+/-), is the length of an unwrapped circle of diameter 1 unit.
I read that the Bonnet transformation, with theta = 90 degrees, turns a Scherk1 into a Scherk2 surface. (?How to script?:-)
(Also applies for catenoid/helicoid, and for D, gyroid, P surfaces...)
6524.20 In reply to 6524.18
>>I've no idea if it can be modified to make nurbs<<
Very interested in hearing more about
6524.21
Mike;
>>I got an .obj file from MathMod and then made it solid in MeshMixer.<<>>One possibility would be to use retopology tools in 3D Coat or something like Topogun to get a quad polygon layout and then use Max's sub-d to NURBS script to convert that to NURBS.<<
is it opssible in Meshmixer to go form triangle to quads `liKe Michale suggested ?
6524.22 In reply to 6524.20
I have constructed a Sherk tower manually but the blends are not really smooth.
Is there a way to expand the Scherkscript so it will stack up saddles to build a tower ?
6524.23 In reply to 6524.22
This is the base unit, for Scherk2 tower, resulting from previously described lineweb, blends, trims, etc.
Just Stack and rotate appropriately.
The complete minimal surface goes to infinity at the poles, I think, precluding a simple "complete" script.
The 7Z file is about 1/3 the size of the .zip file. The 7zip unzipper is a free program.
Show messages:  1-3  4-23  24-34
