Cloth simulation
 1-4  5-24  25-44  45-64  65-73
So I'm guessing, calculate a lot of points, at some density, ?
Turn the points into curves, like a fishing net with square holes?
Apply Network command?
6514.6 In reply to 6514.1
Really cool Max, looks like you're having a lot of fun!
Re: interface - not sure what tips to give on that yet without knowing more details - is the movement of the ball something that's happening in the simulation code as well or is that responding to mouse movements?
I guess first thing that comes to mind with what you're showing there is something to control the grid density of the cloth?
I did a little reading, based upon google search of "verlet integration cloth simulation," and found lots of good sites with excellent information.
Select collision object(s), i.e. the sphere.
Cloth width.
Cloth height.
Grid density, or vertex distance.
Vertex "marble" distance, to prevent self intersection.
Attachment points, if any, i.e. 2 corners.
http://graphics.stanford.edu/~mdfisher/cloth.html
Another site explained collision.
6514.8
Hi guys!
DannyT
>>Is that even possible in MoI?
Yes, it's possible. And it works even faster than I thought before.
bemfarmer
>>How much JavaScript code would that take?
I used three.js javascript library. It's so big! I need to clean all unused functions.
At the moment the code size is about 2000 lines. :)
I think 40x40 points will be enouth.
Michael Gibson
In the first video the ball movement was predefined. But it's possible to control it manually.
bemfarmer
In fact it's very easy. Really. Very simple mathematics.
>>Turn the points into curves, like a fishing net with square holes?Apply Network command?
Exactly! :)
EDITED: 10 Feb 2014 by SMIRNOV
6514.9
Not sure if this is helpful but Blender can also do a cloth simulation thing...
http://www.youtube.com/watch?v=2zd1AI198I8
6514.10 In reply to 6514.8
That is really cool...
Peace,
Rich_Art. ;-)
6514.11 In reply to 6514.9
Hi Sebastian, that's just it, there are plenty of poly modelling apps that do cloth sims, but this is first I have seen of it in NURBS, so unless anyone knows different, this is going to be unique to MoI.
Martin Spencer-Ford
Will the user be able to select a "bending stiffness" for the cloth?
Will there be a "Hair" mode ? :-)
6514.13 In reply to 6514.12
Hi Brian
Afraid not. At least not in the first release.
6514.14 In reply to 6514.11
TpwUK
<<Hi Sebastian, that's just it, there are plenty of poly modelling apps that do cloth sims, but this is first I have seen of it in NURBS, so unless anyone knows different, this is going to be unique to MoI.>>
Agree with you Martin
I understand also Sebastian's point of wiew:he belong to other branch of MOI's users:molders,cnc,3dprinters..for them this stuff could be not necessary
anyway Max that's amazing !! I also saw- Moi3d camera- on your youtube...we have to expect this too??...all for free..?? :) :)
6514.15
Can't wait to try it out. Thanks for your contribute! About interface.. Uhm, guess you could type in the name (group) of the colliding objects, that would make it easy
6514.16
Brilliant! :-)
6514.17
Hello!
Today I've started to making the interface.
I don't know when I'll finish it. I'm very busy at work.
Maybe this weekend.. Maybe later.
6514.18 In reply to 6514.17
Insane Max....... Cant wait to try it!
6514.19
Simply amazing, great work.
[Denis]
| Coreldraw X6 | Moi v2 | Cinema 4D R15 Prime | Daz Carrara Pro 8.5 |
| Intel Core i7-930 | GeForce GTX-660 |
http://spaceland.cgsociety.org/
6514.20
Holy mother of pearl!
Oh... there are going to be possibilities. ;-)
So! Will there be a 'pause' or 'reverse' of some sort? Would you be able to affect it by a chosen object; like the sphere being moved into it?
And yes, rigidity or tensile viscosity would be a nice touch too, but never mind me, I've been amazed at your result and can't wait to play with the final script.
EDITED: 11 Feb 2014 by MAJIKMIKE
6514.21 In reply to 6514.20
I had similar thoughts Mike.
How do you freeze the "cloth" where you want it? Can you single-step through the "animation" and save the desired shape?
Can you output obj files of each step (frame) of the animation? Programs like Element 3D will accept obj sequences and render.
Can you affect the weight or damping of the cloth? That is, can you vary how many wrinkles are produced?
Can you deform anything other than a flat surface? That is, could two spheres collide and leave a dent?
Have you considered a variation of the script to produce ocean water?
This is fantastic work. I'm anxious to try it.
Ed
6514.22
Now that looks like a lot of fun!
Should allow for some nice "relaxing" of surfaces.
Yeah, some control over stretchyness could be helpful and a single-step-mode too to catch the perfect frame...
MoI is starting to really grow up with all the cool scripts you guys are doing!
I never even realized what's possible...
Cheers,
Tom
How about reversing the process?
Think of the Sphere as a sculpting tool, the cloth as a portion of a 3D surface.
So the Sphere would make dimples or rounded grooves in the surface.
6514.24
Hi!
Here is my quick answers :)
Mike
Maybe in next version, but not now.
It's impossible with the current engine. I will rewrite it later.
ed
I don't know. Need to check MoI export tools.
Yes. Yes. Already done.
Surfaces only.
Tommy
>>Yeah, some control over stretchyness could be helpful..
Done.
>>..and a single-step-mode too to catch the perfect frame...
I'm writing it now.
bemfarmer
All frames will be saved. You can rewind the record.
Maybe later.
Show messages:  1-4  5-24  25-44  45-64  65-73
