Cloth simulation
 1  2-21  22-41  42-61  62-73
6514.22
Now that looks like a lot of fun!
Should allow for some nice "relaxing" of surfaces.
Yeah, some control over stretchyness could be helpful and a single-step-mode too to catch the perfect frame...
MoI is starting to really grow up with all the cool scripts you guys are doing!
I never even realized what's possible...
Cheers,
Tom
How about reversing the process?
Think of the Sphere as a sculpting tool, the cloth as a portion of a 3D surface.
So the Sphere would make dimples or rounded grooves in the surface.
6514.24
Hi!
Here is my quick answers :)
Mike
>>Would you be able to affect it by a chosen object; like the sphere being moved into it?
Maybe in next version, but not now.
>>And yes, rigidity or tensile viscosity would be a nice touch too
It's impossible with the current engine. I will rewrite it later.
ed
>>Can you output obj files of each step (frame) of the animation?
I don't know. Need to check MoI export tools.
>>Can you affect the weight or damping of the cloth? That is, can you vary how many wrinkles are produced?
Yes. Yes. Already done.
>>Can you deform anything other than a flat surface? That is, could two spheres collide and leave a dent?
Surfaces only.
Tommy
>>Yeah, some control over stretchyness could be helpful..
Done.
>>..and a single-step-mode too to catch the perfect frame...
I'm writing it now.
bemfarmer
All frames will be saved. You can rewind the record.
Maybe later.
Amazing!
6514.26
Yes! I did it! :)
P.S. Sorry, I'm tired now, so I'll write about this script tomorrow.
P.P.S.
EDITED: 7 Mar 2022 by SMIRNOV
6514.27 In reply to 6514.26
Wow Max that is so super cool!
My favorite part is being able to scrub through all the generated frames at the end!
The spheres are pretty slippery!
6514.28 In reply to 6514.27
"""My favorite part is being able to scrub through all the generated frames at the end!"""""""""
Should be able to do the screencapture on all those frames for a sequential animation!!!! It "IS" very cool.
Thanks Max.
6514.29
Great, works really well. Is it possible in the future to use other objects than spheres?
6514.30 In reply to 6514.26
Absolutely awesome Max!
Here's a quick model and render using the Cloth and vSpray scripts :)
Size: 843 KB, Downloaded: 128 times, Dimensions: 1280x720px
Size: 716.4 KB, Downloaded: 113 times, Dimensions: 1280x720px
Very appetizing Danny
and bravo again Max the Wizard of Script Land!
6514.32 In reply to 6514.30
Hi Danny,
I'm impressed, looks great!
wastzzz
I tested this script with other simple shapes (cubes, cylinders), but I am not satisfied with the quality. A cloth stretched over sharp edges looks really bad.
Also I tested it with complex curved shapes. It works, but veeeerrrrry sloooooow...... I need a fast algorithm for collision detection between points and surfaces.
BTW, Don't forget that you can use a lot of spheres :)
6514.33
Most impressive!
Marc
Hello Max
When you select points does it possible to have a "circular selection" ?
It's possible by hands with your script but it's some tiedous! :)
And will be very useful in many other cases than your script ! ;)
Have happy coding!
6514.35 In reply to 6514.34
Hi Pilou
You read my mind :)
6514.36 In reply to 6514.35
I am a medium! :)
I am making the French version but have 2 questions! :)
http://moiscript.weebly.com/simulation-tissu.html
Where is this text who say to press Done for translate it?
and when I abort and relaunch the script with something selected i have this message
where is it for translate it?
EDITED: 15 Feb 2014 by PILOU
6514.38 In reply to 6514.37
_Cloth.js, line 53
>>and when I abort and relaunch the script with something selected i have this message where is it for translate it?
_Cloth.js, line 13
(forgot to change this message)
I think you should shorten the labels. :)
6514.39 In reply to 6514.38
Thx for the infos! I had researched only on the HTM :)
Seems I can't modify the JS file without this!
In what code I must save the modifications for have French accents ? Normally I use utf-8
Of course I see nothing like this when I read the line 1 before the // !
6514.41 In reply to 6514.40
The mechanism that loads text files like the .js file knows how to load either ascii files or UTF-16 (little endian), so possibly UTF-16 could work.
Show messages:  1  2-21  22-41  42-61  62-73
