CustomUI
 1-18  …  479-498  499-518  519-522
6507.519 In reply to 6507.517
Hi Colin,
> All of which makes me assume it must be part of the original V3 Command Bar install..?
No, those sub-d buttons are not part of the regular V3 UI.
But they may pre-date CustomUI and may have had instructions to insert them by modifying CommandBar.htm .
If you can post your CommandBar.htm I will see if that's where they are.
6507.520 In reply to 6507.519
Thanks for clarifying that.
Here's that CommandBar.htm you're wanting.
HTH, Colin
6507.521 In reply to 6507.520
Hi Colin, yeah they were added in to there.
I've edited them out so if you replace your current CommandBar.htm with this attached version that should get rid of them.
6507.522 In reply to 6507.521
Thanks greatly for that, it's much appreciated.
Just tested & works a treat.
regards Colin
EDITED: 23 Mar 2023 by COLIN
Show messages:  1-18  …  459-478  479-498  499-518  519-522
