CustomUI
 1-15  …  456-475  476-495  496-515  516-522
6507.496
Anyone know of a way to reach out to Max? I'd like to ask if I can repost his plugin. I made a tutorial awhile back and a few moi users are asking about it on youtube. Would reposting a link to download be bad form?
6507.497 In reply to 6507.496
Hi Limi,
I'm really not sure... On one hand removing all of the scripts he had as file attachments here in the forum seems to indicate that he doesn't want to have them distributed anymore but on the other hand they were posted for public access with the seeming intent to have them as open source although there was no specific license attached...
Hopefully someone will be able to get in touch with him to find out what his wishes are. Nobody has had any luck reaching him so far though.
I kind of feel like I shouldn't repost any links myself but if others do I won't remove them unless I receive communication from Max asking for that.
6507.498 In reply to 6507.496
Limi:
Beginning MOI.
If you contact Max, would it be possible to repost the Object Library Mac version from Max. I purchased MOI, and decided to add it to MOI, however, Max is missing. tgoy99
6507.499 In reply to 6507.498
For the moment all from Max is not accessible!
Maybe the war ! ?
6507.500 In reply to 6507.497
Thanks Michael!
6507.501 In reply to 6507.498
Hey Tgoy:
Unfortunately I don't think I have the mac version but if I come across any new info I'll send you a message. Maybe we can look at making a new plugin. I know for me, the object library was main reason I used it.
6507.502 In reply to 6507.499
Pilou:
I'm a bit concerned that's what it is.
6507.503 In reply to 6507.502
Wish the best for him!
6507.504 In reply to 6507.1
Can someone share this file with me? "CustomUI.1.03.win.mac.zip" please!
6507.505 In reply to 6507.75
why didn't this link "http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=78c62a0bee360dcc249f55a194a24190&filename=CustomUI.1.03.win.mac.zip" I need this file. Please help me!
6507.506 In reply to 6507.504
Will delete attachment, if Max so requests.
I do not have a mac, and do not know anything about this (old) version.
EDITED: 30 Apr 2022 by BEMFARMER
6507.507 In reply to 6507.506
Need a customui 2.0 link for windows please
6507.508 In reply to 6507.507
Hi Vorontsov,
Go to https://moi3d.com , then Resources , then on the Resources wiki page there's a link for "Max Smirnov's MoI scripts".
That will get you to the mirror archive.
You have another one here + more few scripts ;)
https://moiscript.weebly.com/scripts-de-max-smirnov.html
6507.510 In reply to 6507.268
Where is the download link???
Please, can you repost the download link, specifically for the ObjectsLibrary extension
I have no idea why it seems impossible to find and I normally can find dead pixels from across the street!
6507.511 In reply to 6507.510
Hi 710avfx, go to https://moi3d.com , then the "Resources" link, then "Max Smirnov's MoI scripts" and it's on the top there.
6507.512
I'm still using V3 & at some point I installed Max's Custom UI.
I've no use for the 4 x Sub-D icons along the bottom Menu pane & so want to remove them.
Looked within Max's instructions for tuning them off...but it would appear it's part of your main MoI coding.
Would you be able to please advise on "how & what" needs to be changed/removed.
regards Colin
6507.513 In reply to 6507.512
Hi Colin, when CustomUI for v3 is installed it has a folder at:
C:\Program Files (x86)\MoI 3.0\ui\customui
Inside that folder there are several .htm files, each one of these files will get loaded by CustomInit.js and will generate one or more buttons on the bottom toolbar.
So if you don't want a particular set of buttons, remove the .htm file from that location and then that set of buttons shouldn't get generated.
If you can't find the one to remove there, please post your CommandBar.htm from the folder C:\Program Files (x86)\MoI 3.0\ui so I can see if those particular buttons have been added directly to the UI instead of set up as a loaded CustomUI module.
EDITED: 21 Mar 2023 by MICHAEL GIBSON
6507.514 In reply to 6507.512
Hi Colin.
I don't remember how in version 3.
In version 4 there is a "startup" directory in which there are the files we need.
Create a folder with an arbitrary name and move unnecessary files to it.
image host image host image host
I looked at the description, everything is simpler there. Find the files whose name starts with a two-digit number, these files control the buttons we need. For example, I don't want to use "Nodeeditor", which means I don't need this button, then we look in the directory for a file named "97 Nodeeditor.js" and change its name to "-97 Nodeeditor.js" which will disable the button. Here is another example, I often use "Nodeeditor" and I need the button in the addon that launches "Nodeeditor" to be the first from the left, then rename the file to this form "01 Nodeeditor.js", which will move the button to the leftmost position.
EDITED: 22 Mar 2023 by WN
6507.515 In reply to 6507.513
Thanks for that & yes, that Custom UI folder was the first place I looked & there's NO Sub-D listed within there.
The actual Sub-D icons are part of the MoI V3 installation as I found them within the Icons folder...
I've attached two screen captures of my MoI V3, first is as a "floating window", second as maximised...
...in both cases I have to scroll across to reach stuff I use because of the Sub-D's which I don't use.
If I can get rid of the Sub-D "placement" then I'm hopeful of getting back to NOT having to scroll.
regards Colin
Show messages:  1-15  …  436-455  456-475  476-495  496-515  516-522
