CustomUI
 1  …  442-461  462-481  482-501  502-521  522
Message 6507.482 deleted 30 Sep 2021 by MARKY
Before that if you have a Windows System you can make that ;)
Key Logo windows + "+" toggle on an Inverse color Interface
Key Logo windows + "Escape" toggle on Normal color Interface :)
6507.484 In reply to 6507.481
Sorry to ask you despite a subject widely documented on the forum. But I'm not sure I'm doing the right customization of my toolbox on my own.
I wish I had Curve / Solid combined into one tab, because currently with my custom palette, when I click on the "solid" tab to open it, the "Construct" tab or the "Transform" tab closes. I think that would fix the problem which I think is a vertical space issue. I attach my files:
In Moi 4.0:
SidePane.htm
SidePaneTabs.js
SidePaneContextArea.htm
SidePaneTitleBar.htm
SidePaneFilename.htm
In Moi > startup:
SeparateSidePanePalettesNotViewSelect.js
In case there is an interaction between them. the rest of the palette suits me as it is.
- Zooen
EDITED: 18 Aug 2024 by ZOOEN
6507.485 In reply to 6507.484
Hi Zooen, that's the intentionally designed behavior that if you open a tab which would cause the side pane to become longer than the available vertical space that it will collapse tabs at the bottom up until there is enough space to fit it without a scroll bar.
The script SeparateSidePanePalettesNotViewSelect.js is making that situation worse by ungrouping all tabs.
What happens if you just remove SeparateSidePanePalettesNotViewSelect.js and let the UI work as it is supposed to?
6507.486 In reply to 6507.485
Thank you for your quick response (on weekends!). I remove SeparateSidePanePalettesNotViewSelect.js, Solid and Curve are combined as I wanted. But I would really like to have Construct and Transform on two separate (therefore open) tabs because they are the two tabs we use the most. As you can see the selector is on the left. I think, but I could be wrong, that with this position it should work.
Can I make a modification to test the desired layout?
- Zooen
6507.487 In reply to 6507.486
Hi Zooen, try putting this attached script into the appdata startup folder. It's a modified version of the other script. This one will only ungroup the Construct / Transform palette and not others.
- MIchael
6507.488 In reply to 6507.487
Thanks Michael,
This is exactly what I wanted, with even better working comfort!
I was even able to slightly increase the UI size!
- Zooen
Message 6507.489 deleted 27 Dec 2021 by CORNEL
6507.490 In reply to 6507.1
Is the link to the file gone? Where is it?
6507.491 In reply to 6507.490
Hi aum,
Yes it looks like Max has removed the file attachment with his CustomUI mod in it, I don't know why.
6507.492 In reply to 6507.491
I was able to get Max's website about a week ago. Now it is "gone", from my location anyway.
I do not know who or how it was caused to go away.
There were some news announcements in the media recently, about unnamed web providers shutting things down...
EDITED: 7 Mar 2022 by BEMFARMER
There is not a world war in this time and some internet sites closed and forbidden!
6507.494
The Wayback machine has it archived.
https://archive.org/web/
6507.495 In reply to 6507.494
Indeed!
Max smirnov's archives !
https://web.archive.org/web/20190716204922/http://moi.maxsm.net/media/files/
but then files "zipped" are not accessible!!!
6507.496
Anyone know of a way to reach out to Max? I'd like to ask if I can repost his plugin. I made a tutorial awhile back and a few moi users are asking about it on youtube. Would reposting a link to download be bad form?
6507.497 In reply to 6507.496
Hi Limi,
I'm really not sure... On one hand removing all of the scripts he had as file attachments here in the forum seems to indicate that he doesn't want to have them distributed anymore but on the other hand they were posted for public access with the seeming intent to have them as open source although there was no specific license attached...
Hopefully someone will be able to get in touch with him to find out what his wishes are. Nobody has had any luck reaching him so far though.
I kind of feel like I shouldn't repost any links myself but if others do I won't remove them unless I receive communication from Max asking for that.
6507.498 In reply to 6507.496
Limi:
Beginning MOI.
If you contact Max, would it be possible to repost the Object Library Mac version from Max. I purchased MOI, and decided to add it to MOI, however, Max is missing. tgoy99
6507.499 In reply to 6507.498
For the moment all from Max is not accessible!
Maybe the war ! ?
6507.500 In reply to 6507.497
Thanks Michael!
6507.501 In reply to 6507.498
Hey Tgoy:
Unfortunately I don't think I have the mac version but if I come across any new info I'll send you a message. Maybe we can look at making a new plugin. I know for me, the object library was main reason I used it.
Show messages:  1  …  422-441  442-461  462-481  482-501  502-521  522
