CustomUI
 1-16  …  437-456  457-476  477-496  497-516  517-522
6507.477 In reply to 6507.476
Hi Psygorn,
> In other words I deactivate that part. the icons disappear from the command bar or browser pan area.
That will result in the icon being blank but I think you'll have a blank area taking up the same size as the icon would have.
> My question is that was it a safe move? or it will cause me problems?
It shouldn't cause any problems.
6507.478 In reply to 6507.477
I think there is no blank unused areas.
If you notice I had removed select buttons hide/unhide button from the Browser Pan area. and I think they are just disappeared without leaving a blank space in their place. I am not sure.
6507.479 In reply to 6507.478
Hi Psygorn, sorry maybe I didn't understand what you were asking about. The "icon" of a MoI command button means the part of the button that displays an image in it. When you said you wanted to get rid of those "icons" I thought that meant you wanted to have some buttons where the image part of the button was removed leaving only the text part still in place.
But it seems that when you said you wanted to remove some "icons" you meant you wanted to remove some buttons entirely is that correct?
Anyway seems that you've got it figured out.
6507.480
just one request: DARK UI
6507.481 In reply to 6507.480
Hi jabber,
It's still a work in progress but here's a sneak peek:
Message 6507.482 deleted 30 Sep 2021 by MARKY
Before that if you have a Windows System you can make that ;)
Key Logo windows + "+" toggle on an Inverse color Interface
Key Logo windows + "Escape" toggle on Normal color Interface :)
6507.484 In reply to 6507.481
Sorry to ask you despite a subject widely documented on the forum. But I'm not sure I'm doing the right customization of my toolbox on my own.
I wish I had Curve / Solid combined into one tab, because currently with my custom palette, when I click on the "solid" tab to open it, the "Construct" tab or the "Transform" tab closes. I think that would fix the problem which I think is a vertical space issue. I attach my files:
In Moi 4.0:
SidePane.htm
SidePaneTabs.js
SidePaneContextArea.htm
SidePaneTitleBar.htm
SidePaneFilename.htm
In Moi > startup:
SeparateSidePanePalettesNotViewSelect.js
In case there is an interaction between them. the rest of the palette suits me as it is.
- Zooen
EDITED: 18 Aug 2024 by ZOOEN
6507.485 In reply to 6507.484
Hi Zooen, that's the intentionally designed behavior that if you open a tab which would cause the side pane to become longer than the available vertical space that it will collapse tabs at the bottom up until there is enough space to fit it without a scroll bar.
The script SeparateSidePanePalettesNotViewSelect.js is making that situation worse by ungrouping all tabs.
What happens if you just remove SeparateSidePanePalettesNotViewSelect.js and let the UI work as it is supposed to?
6507.486 In reply to 6507.485
Thank you for your quick response (on weekends!). I remove SeparateSidePanePalettesNotViewSelect.js, Solid and Curve are combined as I wanted. But I would really like to have Construct and Transform on two separate (therefore open) tabs because they are the two tabs we use the most. As you can see the selector is on the left. I think, but I could be wrong, that with this position it should work.
Can I make a modification to test the desired layout?
- Zooen
6507.487 In reply to 6507.486
Hi Zooen, try putting this attached script into the appdata startup folder. It's a modified version of the other script. This one will only ungroup the Construct / Transform palette and not others.
- MIchael
6507.488 In reply to 6507.487
Thanks Michael,
This is exactly what I wanted, with even better working comfort!
I was even able to slightly increase the UI size!
- Zooen
Message 6507.489 deleted 27 Dec 2021 by CORNEL
6507.490 In reply to 6507.1
Is the link to the file gone? Where is it?
6507.491 In reply to 6507.490
Hi aum,
Yes it looks like Max has removed the file attachment with his CustomUI mod in it, I don't know why.
6507.492 In reply to 6507.491
I was able to get Max's website about a week ago. Now it is "gone", from my location anyway.
I do not know who or how it was caused to go away.
There were some news announcements in the media recently, about unnamed web providers shutting things down...
EDITED: 7 Mar 2022 by BEMFARMER
There is not a world war in this time and some internet sites closed and forbidden!
6507.494
The Wayback machine has it archived.
https://archive.org/web/
6507.495 In reply to 6507.494
Indeed!
Max smirnov's archives !
https://web.archive.org/web/20190716204922/http://moi.maxsm.net/media/files/
but then files "zipped" are not accessible!!!
6507.496
Anyone know of a way to reach out to Max? I'd like to ask if I can repost his plugin. I made a tutorial awhile back and a few moi users are asking about it on youtube. Would reposting a link to download be bad form?
Show messages:  1-16  …  417-436  437-456  457-476  477-496  497-516  517-522
