CustomUI
 1-9  …  410-429  430-449  450-469  470-489  490-509  510-522
6507.450 In reply to 6507.449
Hi Art.
For Windows 10, the %AppData% path should be used. (Type in %AppData% in the windows search box, lower left corner of Windows 10 screen.)
I would suggest first that your C:\Users\<yourUsername>)\AppData\Roaming\Moi folders be unhidden.
(Google "unhide appdata folder windows 10") ...show hidden folders.
Also helpful is to set up a Library "MoiAppData" in File Explorer, for this path to ...AppData\Roaming\Moi, for quick access.
My Library link usually does not show the \Moi text, but the subdirectory is there.
The contents of this ...AppData\Roaming\Moi directory may be:
Folders:
commands (my extra non stock moi _scripts)
customui
nodeeditor
objects
snapshots
startup
There may also be some misc. files there, like MoiColors, moi license keys, etc.
I scanned this topic back 2 years, and did not see comprehensive instructions for install in Moi v4 beta,
although a lot of issues were addressed.
I'd say follow Max's original instructions, but use %appdata%.
Mac link: https://moi3d.com/forum/index.php?webtag=MOI&msg=6507.404
EDITED: 22 Aug 2020 by BEMFARMER
6507.451 In reply to 6507.450
Wow Brian, thanks for this FAST and comprehensive answer.
It is working now. I think your post should be pinned.
Art
6507.452 In reply to 6507.449
Hi art, yes like Brian mentions above for v4 you should install it into the appdata folder, not into \Program Files.
Install instructions are here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
Try using Win+R to bring up the Windows "Run" dialog, and then type in:
%AppData%\Moi
and push Enter. That will open up the MoI appdata folder.
When you unzip CustomUI.2.0.beta2.zip there should be 3 folders that were inside the .zip . The folders are "customui", "objects", and "startup".
These should be copied over to the %AppData%\Moi folder.
So you should end up with:
%AppData%\Moi\customui
%AppData%\Moi\objects
and there will already be a %AppData%\Moi\startup folder, copy the contents of the startup folder in the .zip file into the %AppData%\Moi\startup folder.
6507.453 In reply to 6507.452
Thanks Michael, this is one of the many reasons why MoI is the best: incredible fast answers :-)
6507.454
The screen UI element for numeric input is missing.
This input widget doesn't appear.
Your suggestions will be appreciated.
MindSet
Size: 60.8 KB, Downloaded: 55 times, Dimensions: 161x178px
6507.455 In reply to 6507.454
Hi Mindset, does it not appear only in one specific place or everywhere?
Do you happen to have this set in your moi.ini ? :
[UI]
DisableNumericInputFlyout=y
6507.456 In reply to 6507.455
Bingo! Perfect!
BTW, Mr. Gibson, if I were to attempt to fully express how much I appreciate you, then neither of us would have time left for anything else.
Thank you Sir,
MindSet
6507.457 In reply to 6507.456
Thanks Mindset! :)
6507.458
How can I get a screenshot with a white background when using:
%AppData%\Roaming\Moi\ui\customui\-84 Snapshot.htm
Many Thanks,
Mindset
6507.459 In reply to 6507.458
Hi Mindset, I don't seem to have an "-84 Snapshot.htm" file in the regular CustomUI package. Can you post it?
6507.460 In reply to 6507.459
Thanks Michael,
Maybe I renumbered it for some reason... don't remember.
MindSet
6507.461 In reply to 6507.458
Hi Mindset, the code in there looks like it's already setting a white background.
is that path really where you've got it? For MoI v4 it should be a .js file in %AppData%\Moi\startup and for v3 it would be in the install folder's UI subfolder not in appdata...
6507.462 In reply to 6507.461
Thanks Michael,
Apparently I've been editing the wrong file.
Here is %AppData%\Roaming\Moi\startup\82 Snapshot.js
MindSet
6507.463 In reply to 6507.462
Hi Mindset, so in that one the line of code that sets the background color is line #22:
	moi.view.viewportBackgroundColor = 0xEEEEEE;
That's going to be a light gray color. To make it white change that line to this instead:
	moi.view.viewportBackgroundColor = 0xFFFFFF;
Does that do what you need?
6507.464 In reply to 6507.463
Thank you Michael,
You are a virtuoso! …the exemplar maestro!
That saves me a lot of time.
Shall I delete the ".\AppData\Roaming\Moi\ui\customui" Folder?
MindSet
6507.465 In reply to 6507.464
Hi MindSet, you're welcome!
Yes I don't think it's being used. Double check that it's really \ui\customui though, there should be one in Moi\customui (no "ui") that is being used, that's where the menus for customui are at.
6507.466
That's a great addition to MoI! Thanks for that!
I have a question. Is there a way to redirect the object library to a different folder?
Disk space in C is pretty precious and I really like to "populate" the folder with a pretty large amount of objects.
Thanks!
6507.467 In reply to 6507.466
Hi linograndi,
I think that can be done by editing the ObjLibrary.cfg.htm file which is in the %AppData%\Moi\customui folder.
It contains this:
Object Library;MOI\objects
It's the second piece after the semi-colon that controls the folder that it will use. If it has MOI in there that gets replaced by the MoI appdata folder, so the default value of MOI\objects means it will use %AppData%\Moi\objects .
Try editing that MOI\objects value with a path to your desired folder, like this:
Object Library;d:\some_folder\objects
6507.468
Hello all,
How can I do this:
6507.469 In reply to 6507.468
Hi Psygorn, well the scene browser pane comes from the file BrowserPane.htm so that's one file that you would need to edit.
The place they are going into on the bottom is in CommandBar.htm . So first step is go into CommandBar.htm and find the spot where they are being inserted into. Set up a similar spot in BrowserPane.htm and then edit the CustomUi scripts so they're inserting into the browser pane instead of into the command bar.
The CustomUI scripts are located in your appdata\Moi\startup folder. If you look inside them you'll see something like this in each one:
moi.ui.commandBar.CommandBarCustomUI.insertAdjacentHTML( ...
You'll need to change that to something like:
moi.ui.getUIPanel( 'moi://ui/BrowserPane.htm' ).CommandBarCustomUI.insertAdjacentHTML( ...
Show messages:  1-9  …  390-409  410-429  430-449  450-469  470-489  490-509  510-522
