CustomUI
 1-3  …  404-423  424-443  444-463  464-483  484-503  504-522
6507.444
I GENUINELY appreciate your time, attention ...and most especially your help.
When the button is clicked, it displays a stub, as shown:
However, as you suggest, once I moved "Shortcuts.menu.htm" from...
..\AppData\Roaming\Moi\ui\customui\
to
..\AppData\Roaming\Moi\customui\
it started working as expected !!!
Moi must be the greatest software in the world and a primary reason is how we, the user base, are treated and treat each other on this forum.
Thank you mightily !!!
6507.445
In the upcoming release of V4 have you considered building the custom UI into the release maybe in the installation process can you choose classic UI or custom UI - I think with modern screens and extra pixels the custom UI install is very useful in having those tools ready to go and provide a comfortable working environment that is still simple but extremely powerful.
Just a random thought.
Alex.
6507.446 In reply to 6507.445
Hi Alex, sorry no that's not something I've been planning. It doesn't really fit with the overall design of MoI which is focused on being streamlined and not showing a whole bunch of buttons at the top level all of the time.
But at some point I do want to make a mechanism for managing that area of the UI so you could promote some of your most frequently used commands there.
6507.447 In reply to 6507.446
I haven't tried any sort of custom UI but I did like the idea of a "library" button.
That would seem to be in keeping with the idea of streamlining things.
Granted it doesn't save a lot of steps but it would be pretty nice just the same.
Frederick
It would be nice if snapshot had a popup menu associated with it, for the different modes.
Maybe an html file could do this?
6507.449
Hi guys, a quick (and simple I guess) question: how can I install the Custom UI Beta 2 in MoI 4 (Beta Jan 22 2020)?
What I've done so far:
1) Downloaded MoI 4.0 Beta Jan-22-2020 from http://moi.maxsm.net
2) Unzipped directory and copied into C:\Program Files\MoI 4.0 beta Jan-22-2020
3) Started MoI.exe
After that, I cannot see the custom bar. Is there something I'm missing here? I've been reading the forum, but I cannot find what's wrong. Should be something obvious.
Thanks for your help.
6507.450 In reply to 6507.449
Hi Art.
For Windows 10, the %AppData% path should be used. (Type in %AppData% in the windows search box, lower left corner of Windows 10 screen.)
I would suggest first that your C:\Users\<yourUsername>)\AppData\Roaming\Moi folders be unhidden.
(Google "unhide appdata folder windows 10") ...show hidden folders.
Also helpful is to set up a Library "MoiAppData" in File Explorer, for this path to ...AppData\Roaming\Moi, for quick access.
My Library link usually does not show the \Moi text, but the subdirectory is there.
The contents of this ...AppData\Roaming\Moi directory may be:
Folders:
commands (my extra non stock moi _scripts)
customui
nodeeditor
objects
snapshots
startup
There may also be some misc. files there, like MoiColors, moi license keys, etc.
I scanned this topic back 2 years, and did not see comprehensive instructions for install in Moi v4 beta,
although a lot of issues were addressed.
I'd say follow Max's original instructions, but use %appdata%.
Mac link: https://moi3d.com/forum/index.php?webtag=MOI&msg=6507.404
EDITED: 22 Aug 2020 by BEMFARMER
6507.451 In reply to 6507.450
Wow Brian, thanks for this FAST and comprehensive answer.
It is working now. I think your post should be pinned.
Art
6507.452 In reply to 6507.449
Hi art, yes like Brian mentions above for v4 you should install it into the appdata folder, not into \Program Files.
Install instructions are here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
Try using Win+R to bring up the Windows "Run" dialog, and then type in:
%AppData%\Moi
and push Enter. That will open up the MoI appdata folder.
When you unzip CustomUI.2.0.beta2.zip there should be 3 folders that were inside the .zip . The folders are "customui", "objects", and "startup".
These should be copied over to the %AppData%\Moi folder.
So you should end up with:
%AppData%\Moi\customui
%AppData%\Moi\objects
and there will already be a %AppData%\Moi\startup folder, copy the contents of the startup folder in the .zip file into the %AppData%\Moi\startup folder.
6507.453 In reply to 6507.452
Thanks Michael, this is one of the many reasons why MoI is the best: incredible fast answers :-)
6507.454
The screen UI element for numeric input is missing.
This input widget doesn't appear.
Your suggestions will be appreciated.
MindSet
Size: 60.8 KB, Downloaded: 55 times, Dimensions: 161x178px
6507.455 In reply to 6507.454
Hi Mindset, does it not appear only in one specific place or everywhere?
Do you happen to have this set in your moi.ini ? :
[UI]
DisableNumericInputFlyout=y
6507.456 In reply to 6507.455
Bingo! Perfect!
BTW, Mr. Gibson, if I were to attempt to fully express how much I appreciate you, then neither of us would have time left for anything else.
Thank you Sir,
MindSet
6507.457 In reply to 6507.456
Thanks Mindset! :)
6507.458
How can I get a screenshot with a white background when using:
%AppData%\Roaming\Moi\ui\customui\-84 Snapshot.htm
Many Thanks,
Mindset
6507.459 In reply to 6507.458
Hi Mindset, I don't seem to have an "-84 Snapshot.htm" file in the regular CustomUI package. Can you post it?
6507.460 In reply to 6507.459
Thanks Michael,
Maybe I renumbered it for some reason... don't remember.
MindSet
6507.461 In reply to 6507.458
Hi Mindset, the code in there looks like it's already setting a white background.
is that path really where you've got it? For MoI v4 it should be a .js file in %AppData%\Moi\startup and for v3 it would be in the install folder's UI subfolder not in appdata...
6507.462 In reply to 6507.461
Thanks Michael,
Apparently I've been editing the wrong file.
Here is %AppData%\Roaming\Moi\startup\82 Snapshot.js
MindSet
6507.463 In reply to 6507.462
Hi Mindset, so in that one the line of code that sets the background color is line #22:
	moi.view.viewportBackgroundColor = 0xEEEEEE;
That's going to be a light gray color. To make it white change that line to this instead:
	moi.view.viewportBackgroundColor = 0xFFFFFF;
Does that do what you need?
Show messages:  1-3  …  384-403  404-423  424-443  444-463  464-483  484-503  504-522
